Yeah, I know that trick. I asked you a question which was not answered, yet you asked me a question. I’m not going to waste any more of my time.You made a direct statement that: “….I think it is very likely that the piston deposits significantly worsened while using Valvoline EP.”
Glenda’s information re: oil used aside, show us definitive proof.
You can’t.
There is direct correlation between increased oil control ring piston deposits and increased oil consumption. They are directly related. And, it wasn’t until 25k miles into the swap over to Valvoline’s EP that significant increases in oil consumption occurred. This started and gradually worsened after 60k miles on the engine; and 25k miles into using Valvoline EP. Was it caused by Valvoline? Not conclusive. But it wasn’t prevented either. Meanwhile, the Valvoline R&P has reversed this. So, the oil is at minimum partially to blame. Preventing deposits? It wasn’t good at in this context, for this vehicle. Have an engine easy on oil? Shortish intervals likely won’t ever see a problem running the Valvoline. Severe service on a problem prone engine design? Maybe up your oil selection or just run VRP.You made a direct statement that: “….I think it is very likely that the piston deposits significantly worsened while using Valvoline EP.”
You can’t.
Great questions! This vehicle has sure made me rethink years of experience with oils and vehicles. I’ve never had an oil burner like this. Is it a one off? Do I even gamble with my next and more expensive new vehicle?This is a really interesting report. Very grateful Glenda shared with us. The 5k/6 month OCI is so commonly recommended, usually with the addition of "and you'll never have engine-related problems."
I'm curious, instead of focusing on which oil caused it, what do you all think would have prevented it?
What I think is so interesting is that she clearly cares about her cars and takes good care of them and used good oils and good filters, and even did the 500 mile change, and still developed a significant problem.
- AMSOIL or another boutique?
- More frequent changes with any oil?
- More frequent with a higher quality oil?
- Would an early UOA have shown issues and caught it? If you could go back in time and run a UOA knowing that this issue was developing, what would you have seen?
Some GDI engines are extremely tough on oil. There are so many variables to consider - engine make, design, driving conditions, oil type. Some oils do a better job at keeping combustion byproducts in suspension while running cleaner in high temperature ring areas. Oil formulations vary from blender to blender and are changing all the time. I would normally say oils with great solvency from the use of esters as well as robust detergent and dispersant package, should keep rings clean. Some of most modern oil/add packs we are seeing now (limited via VOA though) are showing lower metallic additives than ever before. So, they're having to rely on other things for cleanliness boosting.This is a really interesting report. Very grateful Glenda shared with us. The 5k/6 month OCI is so commonly recommended, usually with the addition of "and you'll never have engine-related problems."
So is Mobil 1 0w30 the new German Castrol? That's the vibe I've been getting on this forum lately...the oil that can do no wrong, lol.
The Mobil 1 ESP line is readily available and very good - 5w30, 0w30, 0w40 X4.So is Mobil 1 0w30 the new German Castrol? That's the vibe I've been getting on this forum lately...the oil that can do no wrong, lol.
As of now the formula hasn’t changed except in the 5w30 flavor. The approvals are impressive throughout.So is Mobil 1 0w30 the new German Castrol? That's the vibe I've been getting on this forum lately...the oil that can do no wrong, lol.
This and that I’m in mountainous terrain so severe service. But after some testing I hope to find a few oils good enough to handle it.I really think in this case vehicle design is the primary driving issue. JMO.
I believe it’s down to engine primarily and the conditions as well.This and that I’m in mountainous terrain so severe service. But after some testing I hope to find a few oils good enough to handle it.
1) Speaking for myself, this has nothing to do with brand; I have used Valvoline for the majority of my life and it’s got excellent products including their EP.Please!
You haven’t said one word about Das Wunder Oil, also known as Mobil 1 FS 0w-40 possibly contributing to the piston ring deposits!
As expected, anything M-1 on BITOG is worshipped, more especially nowadays with anything labeled with “ESP.”
Until it isn’t! You know, kinda like the Fram Ultra or the Fram Endurance…..!? Suddenly she’s kicked to the curb and there’s a new girlfriend in the picture. Premium Guard!
The reality is your words “not conclusive” and “not prevented, either” demonstrate you have no idea when those piston deposits began.
You say: “…but it wasn’t prevented either.”
Exactly my point. With 58% of the 60k miles run on M-1 FS 0w-40, that M-1 oil did little if nothing to prevent the formation of deposits!
“…..So, the oil is at minimum partially to blame. Preventing deposits? It wasn’t good at in this context, for this vehicle.”
Your words bolded above. And those words apply to your unspoken
M-1 FS 0w-40.
Otherwise, you want several knowledgeable people on BITOG to believe that Valvoline 5w-30 EP, an API SP rated and D1/G3 extended protection full synthetic oil, used five (5) times with 5k mile OCIs, caused the initial formation and accumulation of deposits on the pistons which, in turn, caused that sudden increase in oil consumption?
And God forbid, life was perfect with the M-1 until the Valvoline EP came along, right?
Absent pictures of the pistons and piston rings new, as well as after 35k miles on the M-1, and after 25k miles on the Valvoline EP, your comments are nothing but conjecture and speculation.
And an obvious dislike for Valvoline EP.
I wasn’t retired yet so I was still racking up the miles. If I had to guess 1 to 1 1/2 years.I believe it’s down to engine primarily and the conditions as well.
Question: How many years passed between switching from M1 to Valvoline before the consumption increased? I would appreciate this for context and clarity. Thanks
