Glenda W.
PCV always changed on time. Summer oil temps over 230.Have you checked the PCV valve? Also I'm curious what oil temps you commonly see? I do find with ours it doesn't take much increase over the 1600-2000 cruising rpms to get the oil in the low 220's F
With the dealership 0W20 mystery oil I did see lots of varnish under the fill cap with 6k mile OCI's for the first 8 changes, then I switched to mostly PP Euro 0/5W30 which hasn't removed the varnish that I can see, but is probably better oil I am assuming. I put in 5l and usually seem to drain about 4.4l in a 6-7k mile OCI.
It does get driven fairly hard by my wife, and with the cruise on, it sees a bit of 3k rpm engine braking. I guess in the mountains you could see 4k rpm engine braking for miles at a time if you use the cruise control?
I can't say I've noticed more or less consumption in the 60k miles I've been changing it, but I haven't been recording or measuring carefully.
