Valvoline Restore and Protect Oil Burner Test Results
GW.
Just passed 5k miles on my 4th and final oci of Valvoline Restore and Protect for a total of 20k miles. It’s been hard to keep my mouth shut but here are the details and results!!
2018 Subaru Outback that I bought new. Started burning oil right at about 60k miles. Before that it only used about a 1/4 quart in a 5k mile oci. It started using 1 quart in 5k miles and steadily increased to almost 3 quarts in 5k miles. I was adding a little over a quart every 2k miles when I started this test. I have done every service myself on this vehicle including the pcv valve on time. I’ve only used a couple high quality full synthetic oils at 5k mile oci’s since new. The internals have always been spotless. I used a borescope and found oil wash on 3 pistons confirming my suspicion of stuck low tension oil rings. Here are the oils I’ve used in detail.
500-35k miles Mobil 1 Full Synthetic 0w40
35k-100k miles Valvoline Extended Protection 5w30
100k-110k AMSOIL Signature Series 5w30
110k-130k Valvoline Restore and Protect 5w30
Results with Valvoline Restore and Protect:
1st oci=no change
2nd oci= no change(almost gave up)
3rd oci=added 1/2 qt at 2k miles, 1/2 qt at 4k miles! Used a little over a quart in 5k mile oci.
4th oci=added 1/2 quart at 3k miles and used a total of less than 3/4 quart in 5k mile oci.
So Valvoline Restore and Protect has improved my oil consumption from almost 3 quarts per 5k miles to less than 3/4 quarts in 5k miles. Not 100% but not to shabby if you ask me. I highly recommend people give Valvoline Restore and Protect a try for at least 4 oci’s.
My plan is to run Mobil 1 ESP 0w30 for the foreseeable future. I want to see if this oil will keep my piston rings as is. I will continue to update this thread with any changes.
1st oci=no change
Amazing that it’s “bingo” right at the four OCI’s they recommend …
Also want to add besides the cleaning ability nothing really stands out with Valvoline Restore and Protect. It starts out quiet and by 2-3k gets pretty rackety as it’s probably already sheared to a 20 grade. Subaru timing chains are good for this. ESP in my other Subaru and ones I maintain seems to go the distance.
Nothing wrong with a chemistry change right now
What intrigues me about Valvoline Restore and Protect is that you cleaned things up with a regular off the shelf oil from a name brand. It’s priced competitively and is easy to find. Reduced consumption is a good thing all around. It reduces costs and waste since oil isn’t being burned off. And it can help potentially save future items like the cat and pcv system. So far I’m not seeing a down side.
For the price it really is a game changer.
Amazing some of the "darlings" of oils you used from the get go let it get to 3 quarts in 5K at the first place. It is what it is and thanks for the quality updates. Hopefully things dont revert back with moving forward. You will know eventually and good luck.
I’ll be using Valvoline Restore and Protect every 40K or so on the Toyota as a preventative maintenance item for the foreseeable future. Most engines consume after a while regardless of the oil used.
Perhaps vehicle dependent - I ran two rounds EC30 and two rounds of Valvoline Restore and Protect with zero evidence of cleaning despite killing many filters along the way - so just went back to Mobil 1 bcs it was keeping it clean and zero consumption at 100k …
(5.3L GM) …
