Which oil next? Experiment on 2018 Outback
GW.
I’m under 1,000 miles on my 4th and final Valvoline Restore and Protect oci on my 2018 Subaru Outback oil burner(130k). Full details and results coming soon!!
My next uncontrolled experiment will be to run an OTC oil long term to see if my rings stay clean. I’m willing to be a guinea pig here.
My question for you is out of these two oils easily available at Wally which would you like me to use for the foreseeable future?
Mobil 1 ESP 0w30 (I currently use in many vehicles)
or
Mobil 1 Extended Performance High Mileage 5w30
Is it common in Canada? I can't find anything on google at least for the US. Only listing I've found is a $15 a liter one on amazon.
Very common here, and probably in Argentina too. A five gallon, 18.9L pail costs around $160 C$ or $112USD.
I can get it at one of 500 Canadian Tire stores or cheaper from my local bulk lubricants dealer. Check for a commercial Mobil fuel and lubricants dealer in your area.
www.coolcreek.ca
www.coolcreek.ca
Wow only $22 a gal for that great oil. It's shame we don't get it.
I’m actually going to say EP HM here because that was another oil that I have been considering giving a try in my Civic after I’m done with Valvoline Restore and Protect and they claim that it can remove sludge in just one oil change so that might just help clean up whatever Valvoline Restore and Protect didn’t get.
On our Pacifica, I switch to that in 0w20 from Pennzoil Platinum 0w20 and saw a significant decrease in oil consumption. It used to use 1qt/4000-5000, after the switch it used 1/2qt over a 10000 interval. The level on the stick didn't even concern me. I wouldn't have believed it from an internet story.
Of the two, given a history of oil consumption and getting up in mileage; stick to EP HM. It’s primarily GTL base and designed to go longer so less likely to begin to allow for piston ring deposits. Though, I doubt ESP would either with a conservative interval. That said, extended drain oils tend to be blended with ability to run clean based on what HPL has indicated about their own oils. So, if any oil isn’t marketed as extended drain, maybe shy away if already a history of stuck oil rings
or
Chevron pro ds 5w30
I’m going to use Hps 5w20 in our 18 rogue. It’s only ever saw maxlife syn and schaefers, both in 0w20. I scored a couple case for $60 per case and have been waiting for the weather to warm and to run out my tank of redline fuel system cleaner. Today may be the day!
Mobil 1 ESP 0W30
Years ago I had my buddy run this in a total beater Subaru EJ253 Legacy cvt and it completely halted the oil consumption after many oil changes. Probably 100k miles worth of 10k oil changes and redline daily. EJ253 having larger oil ring spaces than the FB, it was still impressive to me at the time.
Varnish is not sludge, so I don't see a backing why either would offer help with that 🤷‍♂️
What's been your consumption experience with Valvoline Restore and Protect?
Yeah, we’re spoiled with low lubricant prices in Canada, but single quarts are typically a ripoff.
I can’t see there being much of a call for 0w40 Delvac in Texas, but in the upper Michigan peninsula and northern states, necessary for winter operation. HDEO 0w40s became popular in Canada for heavy equipment left outside in remote locations, like forestry and mine sites.
THFs that meet J20D would not be of much use in a hot climate and likely cause “afternoon fade” in hydraulic systems, but a necessity for cold climate operations.
