Why wouldn’t you just buy the 5W-30 ESP off the shelf? Are you starting your engine below about -30?Walmart delayed my order. Looking at PUP 5w30 now.
This is just what I am thinking so not saying its correct. The Valvoline EP cSt at 100c is 8.8, the 5w30 Pennzoil UP is 10.3 and the M1 ESP 0w30 is 12. Someone that drives a lot of highway miles in the WRX group said they actually lost 4mpg on the M1 ESP 0w30 over the 5w30 they were using. Makes me wonder if I need to go that thick or the PUP will be a nice in between from what I was using with the Valvoline 0w20 to the M1. I wont be driving a lot of highway miles but that seems to be a lot of efficiency lost and a big jump in viscosity from the 0w20.Why wouldn’t you just buy the 5W-30 ESP off the shelf? Are you starting your engine below about -30?
No way they lost 4mpg from an oil within the same grade. Apart from the fact that no one could ever come to that conclusion based on an observation of everyday driving. Such a change is deep in the noise between grades, much less within one.This is just what I am thinking so not saying its correct. The Valvoline EP cSt at 100c is 8.8, the 5w30 Pennzoil UP is 10.3 and the M1 ESP 0w30 is 12. Someone that drives a lot of highway miles in the WRX group said they actually lost 4mpg on the M1 ESP 0w30 over the 5w30 they were using. Makes me wonder if I need to go that thick or the PUP will be a nice in between from what I was using with the Valvoline 0w20 to the M1. I wont be driving a lot of highway miles but that seems to be a lot of efficiency lost and a big jump in viscosity from the 0w20.
He said he commutes on the same route everyday and drives to get the best MPG. I cant verify of course but also still wondering if I need to make that big of a viscosity jump from the 0w20 I was using.No way they lost 4mpg from an oil within the same grade. Apart from the fact that no one could ever come to that conclusion based on an observation of everyday driving. Such a change is deep in the noise between grades, much less within one.
They guy has no idea what he’s talking about and is also completely unaware of what he’s up against in making that claim.
That makes no real difference. The variables are there and are much larger than the oil.He said he commutes on the same route everyday and drives to get the best MPG. I cant verify of course but also still wondering if I need to make that big of a viscosity jump from the 0w20 I was using.
Always for wear. And it always helps with fuel dilution. Tolerances? What do tolerances have to do with it?Not sure I buy that a higher HTHS is always beneficial. Up to a certain point im sure depending on the engine and its tolerances. I do agree that 4mpg seems excessive just for oil but who knows. Ive had 4mpg swings on mpg but I dont drive the same exact route for work every day on the highway like I use to. I am not an oil expert either so I just try to learn through others who might be lol.
That’s not correct.Again, Im not an expert but then maybe google is not either?
Engine Tolerances and HTHS:
Modern engines, particularly those with tight tolerances like modern LS and LT variants, are designed to utilize thinner oils with lower HTHS values. This is because tighter tolerances allow for lower viscosity oils to maintain adequate lubrication, contributing to improved fuel efficiency
You’ll be better served by ensuing the engine is in proper mechanical condition and that the tires are properly inflated.If your saying forget fuel economy then get the highest HTHS for the specific grade? If so then I am not disagreeing because fuel economy is not that big of a deal for the wrx really but I want decent mileage in the Outback.
Maybe I will try the M1 ESP in one and the PUP in the other. If one seems to run smoother with less engine noise I will choose that one. I could also just continue to run them and get UOA's for both for multiple changes and see how they do.You’ll be better served by ensuing the engine is in proper mechanical condition and that the tires are properly inflated.
Who said the ESP was too thick for clearances?Since oil can get 40x+ thicker going from operating temp to a relatively mild temperature of 32f (was 25f last night) I'd like to know how esp is too thick for clearances?
Glenda is Roki still making the OEM subie filters?I use Premium Guard XL filters or the clones like Carquest Premium/Microgard Select and just recently Mobil 1oil filters. If efficiency is not a concern the factory Tokyo Roki is a nicely built filter.
Yes. You can still get them. Some use Mazda Tokyo Roki filters on Subarus. I cut this one open recently. Great build quality but no published efficiency that I can find.Glenda is Roki still making the OEM subie filters?
I'm trying to find some sort of current production Roki filter and I'm pretty sure most Subies are M20s with the honda-compatible gasket ID,
Piston slap is not caused by, nor cured by oil choice.SubieRubyRoo
I love that my other post was deleted but your troll is still here which contributed nothing to this thread.
Not saying the oil caused it as it was a known issue with many LS1's back then partly because of the short skirts on the pistons. A different oil made it quiet enough to where I did not notice it.Piston slap is not caused by, nor cured by oil choic
