I wanted a viscosity buffer for fuel dilution in my FA24DIT engine. (260hp turbo)
Note: all temps in Celsius convert if you need F
I was expecting oil temps higher than my FB25(182hp naturally aspirated) powered Subarus which ran between 105C and 115C in normal driving.
So I picked M1 0w30 ESP which is a 12.2cst oil@100c
I found out as I drove my fa24dit powered outback that the oil temps rarely reach 100c and really live between 88C-95C
Even in the summer in conditions that would push my FB25 oil temp near 115C (towing w/ac etc) I never went higher than 98C
If you look at the supplied Chart You will notice that 0w20 at 95C is nearly the same as m1 ep 5w30 at 105C.
I'll let you draw your own conclusions from this
My conclusions were:
1. M1 EP 5w30 - 10.2cst was thick enough to provide a decent viscosity buffer against fuel dilution.. in my application due to its lower than expected oil temps.
no need for the 12.2cst M1 ESP
2. If there ever was a turbo engine that 0w20 was adequate for.. its possibly the FA24dit. (still not buying that one 100%)
