If I can get at least 6000 miles out of it vs. 3000 years ago, I'm calling it synthetic.
0-90% is 100% correct for the intended use of the SDS, which you seem to be ignoring 100% of the time.View attachment 34970
just an example of a company playing fast and loose with the percentages. 0-90%. That’s quite the range.
Since we'll never know the true formulation of any of those products, for no reason other than brand loyalty, I'd pick my oil based on that. Of the choices you listed I'd run the XOM product, a few years back it would have been Pennzoil.sorry if this has been discussed tons of times but I am curious which of the top brand oils are considered the most synthetic as in are made of the higher quality oils?
i know in the end of the day, the final product matters more compared to what base oil was used etc etc, this is just for discussion sake
Lets say we are comparing the following: I will try my best to compare the apples to apple comparison. we will use 0w20 for discussion sake
Castrol Edge 0W20
Pennzoil Platinum 0W20
Mobil 0W20 synthetic normal grey bottle
Quaker State Full Syn 0W20
i am trying to ask which contain the most group 4 or group 5 oils because i assume they are contain mostly group 3 right?
So which would you say is more of a synthetic oil which would I believe also mean is technically the "higher quality" oil.
For lots of folks that’s 6 months instead of the old 3 months many followed.If I can get at least 6000 miles out of it vs. 3000 years ago, I'm calling it synthetic.
Which doesn't necessarily mean highest performing in your particular auto.So which would you say is more of a synthetic oil which would I believe also mean is technically the "higher quality" oil.
Yes.0-90% is 100% correct for the intended use of the SDS, which you seem to be ignoring 100% of the time.
Explain how 0-90% on the Pennzoil SDS is compliant with what you quoted from OSHA. You can cherry pick SDS’s but the truth of the matter is they’re unreliable at best as to the percentagesYup, when we are talking percentage ranges, this is what is being referenced. Which is consistent with what's spelled out in what I quoted from OSHA.
Here is one from Royal Purple:
AMSOIL gives some generous ranges as well. The below shows 10-30% PAO for the whole SS series:
Castrol Edge 0W20
The SDS is there to tell the respective agencies and responders how to prepare and work with a exposure or spill or fire involving the particular substance. That’s all. Trying to figure out a particular brand’s base oil properties is a lost cause here.
Why would the Amsoil ss line be so conservatively valued or is 30% max true? I wouldn't think so but one never knows.
Didn't think of that, what else is new? Thanks OK.They could be using more POE, which doesn't appear to be required to be shown on an SDS.
We are at the mercy of oil companies using hazardous PAO so we can brag about the oil we have in the sumpThe SDS is there to tell the respective agencies and responders how to prepare and work with a exposure or spill or fire involving the particular substance. That’s all. Trying to figure out a particular brand’s base oil properties is a lost cause here.
We are at the mercy of oil companies using hazardous PAO so we can brag about the oil we have in the sump![]()
