Should I trust Jeep engineers on 0W-20?
My Wrangler is 2024 with the 3.6L Pentastar V6. Manual and oil cap say 0W-20 but Pentastars in the past have used 5w30. What has changed? Does the 0w-20 have more additives to make up for being less thick? And has anything changed on modern Pentastars to make them function with 0W-20? I have 11,000 miles on my Jeep and have been using Pennzoil Ultra Platinum 0W-20 since day one.
Educate noob me and show me the right way.
Thanks!
Oh, I live in Seattle and 90+ degree temperature is only a few days in our short summer.
the Pennzoil ultra 0w-20 is a excellent oil , it has all the proper additives and good gtl base oil, the lower viscosity is more in tune with fuel economy results pertaining to the cafe standards ,just stay on top of your oci ,as 6 month/5k intervals and use a good oil filter like Fram ultra or Wix xp,. You will not have any issues with this, you probably could use AMSOIL Signature Series 0w30 if you really drive the vehicle hard or want longer oci,but myself would just use the Pennzoil ultra 0w-20.
Thanks!
Nice Jeep!! Nothing has changed with the engine. You can go to 5w30 or 0w30 without issue. Especially for off-roading.
They’re not picky engines. I have ran 0w20, 5w20 (what mine calls for), 0w30, and 0w40. It will live the rest of its life on HPL Supercar 0w30 because that enables me to get away with a once a year/~12k oil change interval…. And that’s also what I run in my truck so it simplifies everything.
Off topic a bit. My 3.0L Supercharged Jag engine (AJ126) spec's 0W-20 oil. Jag did a great job enlarging the connecting rod bearings to avoid oil related failures. Jag even DLC coated (diamond like carbon, hard coating) the cam followers (buckets) to ensure they would hold up, used coated pistons and even coated timing chain pins.
What actually happens is the main bearings wear, the chains fail once the coatings wear off and the DLC valve bucket coatings are eventually breached by the cam lobes due to inadequate viscosity.
What holds up are the pistons, rod bearings, cam bearings (with special long travel oil passageways) and oil pump.
At this point, some manufacturers get it 100% right, others do not. Here in South Florida, I never run 0W anything.
That didn't take long. Another "thick vs. thin" thread. Perhaps you can find noob nirvana in one of these threads, there are lots more if you need them:
