Running pup 20 weight you're practically running a 30 weight. Usually tests in the 9.5 range at 100c.
Yeah, my wifes 2024 CX-5 and my 2023 Mazda 3 (same engines) say "Recommend" 0W-20, but 0W-20 REQUIRED for fuel economy rating. Which makes sense. They aren't saying you can't use a 30 weight, they're saying you have to use a 20 weight for fuel economy.Take a look at your owners manual. My wife's Mazda CX-5 says to use 0W-20 but if you look in the owners manual that applies to the US and Canada only. Everywhere else says to use 5w30. The US requirement for 0W-20 is a fuel economy thing for EPA standards.
I run 5w30 year round.
How does off roading spec a different oil? This answer should be interesting!Nice Jeep!! Nothing has changed with the engine. You can go to 5w30 or 0w30 without issue. Especially for off-roading.
Off topic a bit. My 3.0L Supercharged Jag engine (AJ126) spec's 0W-20 oil. Jag did a great job enlarging the connecting rod bearings to avoid oil related failures. Jag even DLC coated (diamond like carbon, hard coating) the cam followers (buckets) to ensure they would hold up, used coated pistons and even coated timing chain pins.
What actually happens is the main bearings wear, the chains fail once the coatings wear off and the DLC valve bucket coatings are eventually breached by the cam lobes due to inadequate viscosity.
What holds up are the pistons, rod bearings, cam bearings (with special long travel oil passageways) and oil pump.
At this point, some manufacturers get it 100% right, others do not. Here in South Florida, I never run 0W anything.
I didn’t say spec(although many oem’s do spec going up a grade). It’s considered severe service. I’m sure your rebuttal will be useless, I mean interesting!How does off roading spec a different oil? This answer should be interesting!
You answered your own question:
The Pentastar was designed for 5w30.
The engineers didn't necessarily write the current owner's manual, it was written with CAFE in mind.
Some manufacturers suggest that when using the vehicle in more severe service, to kick the viscosity up another notchHow does off roading spec a different oil? This answer should be interesting!
Wow, thanks, I feel good. Can you please explain more how it is like 5W30Running pup 20 weight you're practically running a 30 weight. Usually tests in the 9.5 range at 100c.
YeahIs this the jeep you are doing 2500 mile oil changes and 25K mile coolant changes on
More additives don't make up for higher viscosity?Some manufacturers suggest that when using the vehicle in more severe service, to kick the viscosity up another notch
20 weight PP and pup virgin oil tests usually test out as having a viscosity of around 9 to 9.5cSt at 100 degrees Celsius.Wow, thanks, I feel good. Can you please explain more how it is like 5W30
I run 0w20 in my Silverado. Towing 5,000 pounds up 9,000 foot passes in 90 degree heat. How much more severe should I worry about?Some manufacturers suggest that when using the vehicle in more severe service, to kick the viscosity up another notch
I am not sure if there is an "off-roading spec" as you put it.How does off roading spec a different oil? This answer should be interesting!
