Interesting. No TSB then? They're just coming in with wiped cams after 5k OCI?Not sure, but the mechanics are on the max 5k miles OCI.
10% is definitely an exaggeration, but they do make some difference. By switching to a smaller rim you are essentially replacing some of alloy wall with rubber wall, if that makes sense. That to a degree reduces unsprung mass, and makes a bit of difference on the track. On a street application I could imagine maybe a percent of fuel economy advantage? I am just making it up, i havent seen any numerical data on that so just speculating.If that were true, EPA would have never allowed, and almost no manufacturers would have taken the CAFE hit if they could pick up 10% by sticking with smaller diameter rims.
My vehicle comes with 18s or 20s depending on trim level, and considering that the Touring trim with 20s weighs several hundred pounds more in luxury upgrades over the base model with 18s and suffers less than a 3% mileage hit, I’d love to see some industry data backing your 10% claim as I’d switch tomorrow if that were true.
No, the mechanics opinion is to go with 5k OCI. Not sure where you're going with TSB comment.Interesting. No TSB then? They're just coming in with wiped cams after 5k OCI?
Got it! Yet, I'm sure most customers are going 10k OCI. TSB comment was if the manufacturer has acknowledged an issue.No, the mechanics opinion is to go with 5k OCI. Not sure where you're going with TSB comment.
OEMs love this.Got it! Yet, I'm sure most customers are going 10k OCI. TSB comment was if the manufacturer has acknowledged an issue.
But how is the taste?One bottle of slick 50 for me and I don't worry about anything!
Starting to look at torco 0w20 for my next OC. I used to run torco in my Ducati, that is a fantastic oil but it's fairly costly.But how is the taste?
You should never put anything but high quality oil that meet the spec what manufacturer recommends. Adding snake oil, reduce the effectiveness of oil formulations that expensive to develop and tests.One bottle of slick 50 for me and I don't worry about anything!
My experience switching to Mobil 1 Advanced Fuel Economy 0w30 has been awesome so far
All of you?
You know well what you are talking about. I did some reading about Pennzoil Ultra Platinum 5w30. It's ccs(4000) and mrv(10,200) are superior to the likes of Redline and HPL, and to Pennzoil Platinum It gets beat only by AMSOIL Signature Series, just by a hair. Shell oils are pretty good.seems like the Pennzoil 5w30 ultra acts like a 0w30 in the mrv and ccs testing compared to some 0w30 other oils, perhaps due to the GTL base fluid used and other additives.
I'm sure we can go really really old school and use castor oil like the ww1 planes used in rotary engines. Castrol got their start in that and it is pretty high viscosity (never mind that once the oil vaporized from the heat, inhaling it had some interesting side effects so that pilots had to take stomach medication before they even started their engines)Weak, 10w-60
Shell is probably gold standard when it comes to engine oils. For the price and performance it handily beats HPL, Amsoil type boutique brands across several criteria.You know well what you are talking about. I did some reading about Pennzoil Ultra Platinum 5w30. It's ccs(4000) and mrv(10,200) are superior to the likes of Redline and HPL, and to Pennzoil Platinum It gets beat only by AMSOIL Signature Series, just by a hair. Shell oils are pretty good.
A lot of the people that purchase Amsoil, HPL, Redline are mostly interested in extended drain intervals or just prefer to have performance edge through out the interval. Pennzoil is good oil. PUP is good for longer intervals. However throw 5%+ on any of those Shell products and they will tank compared to the so called boutique oils. At the end of the day every application is different so not everyone has the same needs.Shell is probably gold standard when it comes to engine oils. For the price and performance it handily beats HPL, Amsoil type boutique brands across several criteria.
Throw 5%+ of what? Fuel dilution?A lot of the people that purchase Amsoil, HPL, Redline are mostly interested in extended drain intervals or just prefer to have performance edge through out the interval. Pennzoil is good oil. PUP is good for longer intervals. However throw 5%+ on any of those Shell products and they will tank compared to the so called boutique oils. At the end of the day every application is different so not everyone has the same needs.
Yes I forgot to add the word fuel.Throw 5%+ of what? Fuel dilution?
How do boutiques stand up better against fuel dilution? Isn't it primarily just mixing a higher viscosity oil with a lower viscosity liquid (fuel)?Yes I forgot to add the word fuel.
Just take a look at all the UOA. For example signature series. Outperforms most off the shelf oils with same viscosity and approvals.How do boutiques stand up better against fuel dilution? Isn't it primarily just mixing a higher viscosity oil with a lower viscosity liquid (fuel)?
It is just the same within the error bar, how people drive, weather, and samples variant. It is wear number/Sqrt( number of sample-1)Just take a look at all the UOA. For example signature series. Outperforms most off the shelf oils with same viscosity and approvals
