Top off with a heavier oil for 0w-20?
For an already thin oil like 0w-20 would it make sense to top it off with something heavier, like 0w30 or 0w-40, to make up for the fact it's thinning as you get closer to your OCI? If an engine takes 4 quarts and you have to top it off with 0.5 quarts, would you choose 0w30 or 0w-40 to help bring it back closer to its viscosity when it was new? Let's say the OCI is 10K miles on engines with low tension rings.
None of this makes sense as a baseline condition. Why would you push an oil to 10k OCIs if you believe it's shearing excessively?
Isn't the obvious thing to drain the oil before it's sheared excessively? Or run a higher grade oil that is capable of meeting 10k OCIs in grade?
Or running a thicker grade oil to budget for the expected shear?
Either the shearing is concerning enough to drive the shorter OCIs or it isn't. If it isn't, then just stop off as normal. If it is, don't run 10k OCIs.
My cars typically take a touch over 5 quarts, so I add that bit "extra" with whatever I have lying around. API SP oils are compatible with each other, so not going to harm anything. Certainly not ideal, but won't hurt anything.
And here there’s no evidence being presented that the oil is thinning due to mechanical shear of the VM. In fact there’s no evidence any oil is thinning by any means.
... Unless I knew for sure that the 0w30 and 0W-40 variant of that specific oil brand and series uses the same additive chemistry, I wouldn't bother. ... .
Good advice.
My new Subaru came with 0W-16, I would likely not top off with anything other than this low HTHS lubricant that relies more than ever on the additive package to perform adequately.
Hopefully I will not have to add, as I likely cannot obtain the FF Idemitsu chemistry stateside - just the dealer parts counter stuff from Idemitsu Lubricants in Indiana. Maybe it's the same juice.
I was nonplussed with the last Subaru Genuine 0W-20 I ran in the Wife's '23 Crosstrek. Odd as it has been stellar each time in the past. I Do not recall if it was API SN or SP.
You didn't mention the year of the vehicle but most newer cars have thinner rod bearings and main bearings than years ago (in my day).
The tolerances are also tighter. All designed to cut down on CO2 emissions. If you use too thick an oil in newer engines it can actually result in lubrication starvation.
This is what I've gathered from reading a lot of forums on auto repair anyway.
Can't guarantee the validity.
Oh, I see this has already been addressed. Good for you. We're all learning.
Other than the Macan, there isn't a vehicle in my signature list that is using the prescribed oil. they range from 9 to 20 years old. All of them run like a top. The sienna is closest, but even that has been "back certified" for 0w20.
It helps when you start to understand that what’s in the owner’s manual is a recommendation.
My 2022 Sierra Limited 5.3L ecotec 3 tends to not use any oil until it reaches 5K mi, then it will burn about a ½ qt. by the time I reach 6K miles. I’ve used 0W-20 from AMSOIL Signature Series, RP and Castrol Edge with the same results.
2022 Sierra Limited: 132K mil, Castrol Edge 0W20 API SQ, Purolator Boss
Differentials & Transfer Case: Redline
Transmission: AC Delco ULV, Lubegard Platinum
Continental Terrain Contact H/T 275/60/20
K&N Air Filter
Oil Catch Can
Fumoto Drain Valve
K&N Air Filter
Oil Catch Can
Fumoto Drain Valve
Have you done a used oil analysis? It's probably fuel diluting and at that mileage, the amount of fuel in the oil gets to the point where the volatility level is allowing burn-off.
I would top off with 0W-30, but then I would have started with 0W-30 aswell.
I recently did a Blackstone used oil analysis at about 4,200 miles on the oil. Came back very good with 0 dilution and very low metals, 3.5 tbn. But, you’re right. After about 5,000 miles things start going haywire. They recommended I change my oil at 6,000 miles. That is typically the 20% oil life left showing on my OLM. I used to go 7-7,500, about 60% highway miles at speed limit.
I recently did a Blackstone UOA at about 4,200 miles on the oil. Came back very good with 0 dilution and very low metals, 3.5 tbn. But, you’re right. After about 5,000 miles things start going haywire. They recommended I change my oil at 6,000 miles. That is typically the 20% oil life left showing on my OLM. I used to go 7-7,500, about 60% highway miles at speed limit.
Shocker.
Blackstone doesn't measure fuel properly, you would have been better off sniffing the oil, lol. Get another UOA, but send it to OAI this time, that way you'll actually know for sure.
K&N Air Filter
Oil Catch Can
Fumoto Drain Valve
I think what Overkill said is right it's likely fuel dilution. I've seen that happen before.
As others have said, Blackstone's fuel dilution value should be taken with a grain of salt. It's wrong more often than it's right. This is because they're essentially guessing, not actually measuring it. You'd have better luck hitting a 300m target with a blunderbuss. I've seen too many cases of Blackstone reporting "trace" or no fuel dilution where GC found 4% or more.
If I have a vehicle that requires 6 qts of oil and it's a half a qt low , I have no problem topping it up with whatever is handy . I've done it and never looked back .
  • Like
Reactions: SR5
I’ve said this before, but I really don’t understand how a company as large as Blackstone, which must be the most successful oil analysis lab, refuses to invest in the proper equipment to do a GC test for the level of fuel in the oil 🤔 Many other small labs have done that. It’s time that Blackstone did the same!
