Amsoil's is a tiny bit lower.seems like the Pennzoil 5w-30 ultra acts like a 0w-30 in the mrv and ccs testing compared to some 0w-30 other oils, perhaps due to the GTL base fluid used and other additives.
That is not an option on any of my vehicles.Their is an easy solution to the dry start. Prime the filter every time you start the vehicle. It makes a huge difference
I see 0W20 as a better quality, more robust, with better additive packaged oil vs 5w20.I have a Jeep GC Limited 3.6 V6 and used O-20 till the warranty was over and went to 5-20. Not much difference in the two. Next OCI I will go to 5-30. Here in Fla today at 7AM it was 88 degrees and 94 at noon. My reason for 5-30. I also have a GMC Canyon with a 3.6 in it and between the two motors there doesn't seem to be much difference. Same cam, valve rockers and cam chain araingement is basicly the same. I will now be able to also have one oil for both which is Mobil 1 5-30 changed at 20% or 6000 miles.
Heck, so far on HPL PCMO15w-40 I'm seeing no MPG penalty relative to VRP 5w-30 or the 0w-20 that was in it when purchased.Since my Mazda is no longer under warranty its on 5W-30 it has made zero difference and over that extended period there is zero change in my MPG vs 0W-20.
I agree, and if the temperature is not a factor in starting, 10w-30 might even be better as there would be less "shearable" additives to keep the oil thickened at running temperature.Unless you are starting your engine at about minus 35 F, there is no difference in "dry start" (however you choose define that) performance between a 0w-30 and a 5w-30. Lots of things to worry about...but this isn't one of them.
Are you buying it from Canadian Tire? In Ontario they put all of the M1 oils on sale at the same time, so if AFE is on sale then so is EP and ESP, and the stores here have a good amount of stock of ESP.I’ve been using Mobil 1 AFE 0W-30 for many years and nearly 200k km’s in our 2007 K24 Accord. Our temps here range from -35 C in the winter to +35 in the summer. I’ve never done a UOA, but from others I’ve seen this oil shows good wear numbers. Our Accord runs great and uses almost no oil, 0.1 to 0.2 litres (quarts) in 6000 to 8000 km’s OCI’s.
I would use M1 ESP 0W-30, but it’s pricier, a little harder to find on the store shelf and doesn’t go on sale as often as AFE.
I thought you said 30 grade was too heavy for your application in another thread?My experience switching to Mobil 1 AFE 0W-30 has been awesome so far. Can't wait to rack up some miles and do a UOA. I am still getting great gas mileage, nothing has changed. I am a happy camper.
View attachment 293671View attachment 293672
Yes, Canadian Tire or Walmart. ESP 0W-30 just doesn't seem to be stocked as well as 0W-30 AFE, although ESP 0W-20 is always on the shelf at my local stores.Are you buying it from Canadian Tire? In Ontario they put all of the M1 oils on sale at the same time, so if AFE is on sale then so is EP and ESP, and the stores here have a good amount of stock of ESP.
That was once true, (and still is for petro oils) but for most modern synthetics, it just means they're using a cheaper mix of base oils.I agree, and if the temperature is not a factor in starting, 10w-30 might even be better as there would be less "shearable" additives to keep the oil thickened at running temperature.
2021 Jeep GC 3.6 4x4. Owned since new currently with 87k. Used various brands of 0w20 with Valvoline flavors for the last 20k. Mostly 5-6k intervals. Switched to Amsoil SS 0w-30 for this oil change.
I know this isn’t a laboratory test. But this trip we take from Ohio to Florida is one we take every summer for the last 16 years with the same route without deviation. Once there our vehicle sits for the week and we take the FIL’s van when we go places. So it’s as close to a consistent “real world” experience as I can personally get.
Engine: The 3.6 is relatively noisy as is. With the 0w-30 it sounds less raspy and smoother. I felt no noticeable drag on the engine.
MPG: The cars computer is relatively accurate. The car has the total trip MPG listed at 24.6. I logged my fill ups and by hand it came out to 24 even. Last year with 0w-20 on the same trip the car had it listed at 25 with by hand calculation it was 24.2. So I guess technically it lost a fraction of MPG’s with 0w30 but in my opinion that could be just in the margin of error.
Oil Temperature: With 0w-20 oil temperatures would top out at 199 degree. Usually sitting at 194 most of the time. I don’t ever remember it hitting 200 on these trips. With 0w-30 it sat at 197 most of the trip but would peak at 204.
Oil Pressure: With 0w-20 during idle and cruising it sat at 30 psi and top out at 78 psi under hard acceleration. With 0w30 during idle/cruise it sat at 31-32 psi and top out at 82 psi under hard acceleration.
Oil Usage: During these trips I’d usually “top off” a small negligible amount to bring it back to the top of the full mark. This trip it’s stayed exactly on the same full mark. No top off needed.
With my OCD I researched for months going back and forth on if I should move from a 20 to a 30 weight. With these engines having dry start concerns I landed on 0w30 over a 5w-30. Will it all make a difference in engine life? I have no idea, I sure hope so! Thanks for reading.
Nice, that’s vw504 spec. It’s as thick of a 30 grade as it gets, with a hths of 3.5. Dexos1 only does 3.2, so this is better for chains I believe. This oil is good. If want to save mpg, run smaller tires. No need for 19s and 20s on every car. You’ll save 10% in an instant, across the industry , and not worry about all these gimmicks.We run Castrol Euro 5w40 in my buddies 17 Pacifica 3.6l with no ill effects. When his wife got it back she asked why it was quieter. So run a 0/5w30 with confidence.
If that were true, EPA would have never allowed, and almost no manufacturers would have taken the CAFE hit if they could pick up 10% by sticking with smaller diameter rims.No need for 19s and 20s on every car. You’ll save 10% in an instant, across the industry , and not worry about all these gimmicks.
Is this is due to defective parts manufacturing or long OCI?Can't hurt with the wiped lobes I've been seeing in the shop (Jeep dealership). Common failure with these are the cam sprockets. Seen the back orders go 3 months or more.
Not sure, but the mechanics are on the max 5k miles OCI.Is this is due to defective parts manufacturing or long OCI?
