Mobil 1 Supercar 0w40, Amsoil Signature 0w40, Mobil 1 ESP 0w30 in the 2024 Pentastar 3.6, spec'd for 0w20, run its VVL/VVT, just fine.
The resurrection of the dead....No, this horse has been beaten to death more times than I can count.
It happens a lot around here.The resurrection of the dead....
In the absence of MRV etc - might be better than nothing …Well I guess its a rough indicator of how it will do at -40C? The odd time I've started a vehicle in cold down near the engine oils pour point, it definitely showed that a few degrees above this number is the limit for a normal sounding start!
I would've guessed a 0W8 synthetic would have a lower pour point than a 0W30, but also there's conventional 10W30's that "pour" at -42-44C. At a more common -20C all these oils will be fine in a normal car engine that spec'd 0W8.
A plug in hybrid is the special case where the engine oil goes from cold to running at operating rpms and power, and maybe never warming up, so I guess these 0W8's have a place there?
Yes, if you are looking at 100C viscosity, HTHS, flash point, shearing tests, NOACK, often a smaller viscosity range conventional oil is tests better than a wider spread synthetic. My theory for stuff that get worked very hard, and not often started in the extreme cold, is to run an oil that wins on those specs, and not worry if its "synthetic" or not. Same with my tractor hydraulic / transmission fluid, regular duratran from petro-canada actually flows pretty decent in the cold, and it should be better at taking the heat/stress of being in a little HST tractor doing its best at big tractor jobs. None of these are regularly started in anything much below -15C, so cold flow isn't really important in that case?In the absence of MRV etc - might be better than nothing …
Here’s something interesting when you look at pour point and flash point of the 10W-30 …
Yep. Lots of Grp2+ in the mix these days called semi or synthetic …Yes, if you are looking at 100C viscosity, HTHS, flash point, shearing tests, NOACK, often a smaller viscosity range conventional oil is tests better than a wider spread synthetic. My theory for stuff that get worked very hard, and not often started in the extreme cold, is to run an oil that wins on those specs, and not worry if its "synthetic" or not. Same with my tractor hydraulic / transmission fluid, regular duratran from petro-canada actually flows pretty decent in the cold, and it should be better at taking the heat/stress of being in a little HST tractor doing its best at big tractor jobs. None of these are regularly started in anything much below -15C, so cold flow isn't really important in that case?
My tractor dealer/diesel mechanic whose been into lots of engines/ equipment put me onto that, just because its "synthetic" doesn't necessarily mean its better for what you are using it for.
So I run 15W40 RT4 in the tractor engine, atv, dirt bikes, all OPE, as they can get worked very hard, and the oil is very cheap in a pail too, so a 10hr OCI's on the dirt bikes without oil filters, is preferable to running a "better" syn for 4 times the cost for twice as long, as it might even shear down faster too!
Shell has started not publishing as many test spec's now so I'm looking to switch, as I need to compare numbers when I chose an oil, not marketing BS or the weasel words around meeting specs without actually getting the accreditation.
In -15c you can run literally anything. 15W40 was name if the game in Europe in 90’s. -30? Who cares. Cars parked outside, of course.Yes, if you are looking at 100C viscosity, HTHS, flash point, shearing tests, NOACK, often a smaller viscosity range conventional oil is tests better than a wider spread synthetic. My theory for stuff that get worked very hard, and not often started in the extreme cold, is to run an oil that wins on those specs, and not worry if its "synthetic" or not. Same with my tractor hydraulic / transmission fluid, regular duratran from petro-canada actually flows pretty decent in the cold, and it should be better at taking the heat/stress of being in a little HST tractor doing its best at big tractor jobs. None of these are regularly started in anything much below -15C, so cold flow isn't really important in that case?
Which Group 2 oils are called synthetic?Yep. Lots of Grp2+ in the mix these days called semi or synthetic …
None - but EHC targets cheap “synthetic” and “semi’ finished lubes …Which Group 2 oils are called synthetic?
If you drink a cup of coffee and listen closely to each and every sentence this Jason guy says, there is a WEALTH of information to learn about this stuff for a big dummy, ill-informed guy like me. REALLY GOOD STUFF if you are interested in engine oils! Thanks for posting @rstcso !Suggest watching these videos if you want to understand viscosity in auto engines and the effects of changing it.
Actually meet the required performance level.None - but EHC targets cheap “synthetic” and “semi’ finished lubes …
(Reduce the grp3 percentage and still meet marketing numbers) …
All that does is TRY to get THEM out of your warranty period. Oil is not a fix for poor design/QC.I'll just toss out there that GM recently shot all the way up to 0w40 for a large population of VVT V8's that already had problematic lifters.
Where have you seen these restrictions for dexos3? Can you post a link? I've never seen a license or approval with base stock requirements, just performance.in order to meet dexos 3 ,the base oil can be up to 30% group 2 and rest G3, mix. most blenders use g.3 ,including GTL in some instances. Often times its at the supply on hand and of course blending variances. that's why the SDS have variable amounts on it.
Are you running this on wet clutches? I just looked at the certifications and had no idea it was JASO MA/MA2. I like my Ultra1Plus, but it’s way too expensive compared to this.So I run 15W40 RT4 in the tractor engine, atv, dirt bikes, all OPE, as they can get worked very hard…..
On the pails I get of 15W40, it does have the JASO-MA rating, but then some specs online don't have it, or other pails don't, but they have a picture of a dirt bike on it? In any case, its certainly not an "energy conserving" motor oil that you must avoid, and many people here run non JASO-MA oils in their street bikes, which have relatively delicate clutches compared to my stuff. I just buy a pail every time its on sale, and it seems that's the rate we use it at. The boys are probably are near 20 oil changes/year on their dirt bikes, as they can put 10 hrs on in a weekend if we don't have something else going on. And the oil does come out looking used! So I'm happier to just change it on these air cooled honda's.Are you running this on wet clutches? I just looked at the certifications and had no idea it was JASO MA/MA2. I like my Ultra1Plus, but it’s way too expensive compared to this.
somewhere on this site? a while ago (with in this past year) but do remember seeing this 30 % amount for the Dexos gen 3.Where have you seen these restrictions for dexos3? Can you post a link? I've never seen a license or approval with base stock requirements, just performance.
I agree. Maybe OP is ascribing the issue to the wrong variable (viscosity), but something clearly changed. I think everyone could be more charitable and try to figure out what caused such a drastic change. Probably just true, true, and unrelated, but you can't blame OP for wondering if it was the viscosity and coming here for help and with a hypothesis, just to get dogpiled.I think outright dismissal of anecdotal information is bad. It very well may be that this particular engine under these particular circumstances does prefer 0w-20. It is entirely possible.
