5W-30 to 0W-20?
A Barrier Island
Lots of chatter and documentation about going from thin to thick but no so much about going the other way. Could I go from recommended 5W-30 to 0W-20 in my Suzuki? It has a n/a, port injected 2.4 L4 engine. Chain drive timing system, no cam phasers. Normal compression ratio, uses 87 octane gas 56K miles, uses no oil between OCI. Mated to a JATCO cvt and driven gingerly
Asking because I have a surfeit of 0W-20 to use up as I only have one car that specs that viscosity.
Stick w/the grade in the manual. That being said if you're running that 20 grade for a few thousand each interval to use it up I don't think it will harm much. Go back to 30 once you can. Unless you have like 50k worth of 20 grade I'd say no way.
The winter rating you want is determined by your expected starting temperature.
Grade illustrates the minimum HT/HS. I would not use an oil that has a lower. HT/HS then recommended. You can go up with no issue but going down is not a good idea. Film thickness protects against wear and a higher grade is beneficial.
Sure, in very cold weather as in Alaska, that would be 100% appropriate. In less severe cases simply pick a quality 5W-30 synthetic. Some of the best ones have pour points in the -70ºF range. So there is near zero risk of oil starvation on startup.
Yet a 5W-30 still only achieves a 5W winter rating. That shows how the pour point does not accurately illustrate winter performance - especially in the aspect of gelling near the pickup under shear and causing starvation.
If 5W20 is a choice in the manual then 0W20 is fine but if 5W30 is lowest grade stay in grade.
If I was forced to use a really good 0w-20 like pennzoil ultra platinum or Mobil 1 ESP in my 5w-30 spec 5.3 I wouldn't panic. If it was cheap 0/5w-20 maybe.
5w-30 is minimum 2.9 hths and stuff like Valvoline conventional lists 2.9 for the 5w-30 but more for the 10w-30.
0w-20 is usually 2.6 sometimes 2.7. Not a big difference.
I'd rather buy some thicker oil like 20w-50 and mix it. I've done that before with 5w-20 I got super cheap.
Polish manual.
So xW20 in hot climate probably not the best idea. How much 0W20 do you have?
I vote for frankenbrew time.
Why is that? Technical reason please.
The oil companies tell us so. There was a recent post on here that said their 0w protects the same as their 5w posted right on the bottle as an example. I would say to be clear from my perspective is that if it's the same type of product line then going from a 0w to 5w...no difference. Run that 0w you always wanted to... :)
