Is 5w-30 too thick for modern cars?
So I recently purchased a 2019 Lexus is350.
It has a 2GR-FKS V6 in it.
Obviously the factory calls out for a 0w-20 oil.
Dealer had new 0w-20 in it, so after 5K miles, I swapped to 5w-30.
I figured running Mobil 1 Extended Performance 5w30 oil was fine since the early 2010s 2GR listed 5w-30 as the recommended oil.
I've run that 5w-30 EP oil in many cars that went above 300,000+ miles.
Within a day, the engine was running oddly.
The exhaust tone on mid throttle sounded weird. Kinda like a drone.
I thought it was leaking exhaust gaskets, but I changed them to no avail.
My brother had mentioned that some modern cam phasers don't like thicker oils. And since it's 50F out, I thought maybe the oil just wasn't flowing right.
So I used an OBD2 scanner to see what the cam angles were.
And sure enough, the cam timing was kind of erratic and laggy.
So I changed the oil to a Mobil 1 Extended Performance 0w20 and the issues are all gone.
No weird noises
Cam timing is consistent
And the car feels more responsive.
I always thought the difference between 0w-20 and 5W30 oil was minimal or non existent.
Apparently not
No weird noises
Apparently not
