5w-30 too thick for modern cars?
I can see how thicker oil could mess up a VVT solenoid.
Some have very small oil passages.
Seen a few 1.8L 1ZZ engines run like crap when bad maintenance clogges up solenoid passages.
Big difference between debris and oil molecules.
5W-30 does not affect VVT operation. Believe me I know.
I guess diagnosing and testing the car is "trolling".
Imagine thinking I'd spend $80 on oil tests to troll.
I don't think your generation even understands what that word means.
What generation would that be?
Please tell me how paying for a oil analysis is diagnosing a closed loop control system?
Or my original question - how can viscosity of an oil affect VVT cam position?
You are the diagnostic expert after all.
0w-20 in winter,5w-30 in summer months, should be no problem, Pennzoil Ultra Platinum is a good oil which I run in my Subaru with no ill efects mpg stays the same,and not sluggish.
On startup both 0w20 and 5w30 are very thick. Does your VVT fail to work at startup? No.
When the oil temperature with 5w30 is 235F and the viscosity is lower than a 0w20 oil with a temperature of 180F, does your VVT fail to work correctly? No.
Does a 5w30 oil have a functionally different ability to be pumped through the holes in the VVT solenoid? No.
Bad maintenance has nothing to do with viscosity.
