Hello all, I have a 2015 F150 5.0 (Gen 2 coyote v8 engine) that I purchased not long ago. Very very long story short...I eventually found out that the engine was sludged. Extremely sludged. So I decided to dismantle the engine and clean it by hand, replace any parts needed, and reassemble it. I'm just a couple weeks away from having it reassembled and running again. Over 90% of the sludge is gone, and there are only a few really small places/corner that have a little sludge residue left. Ford originally called for 5W-20 in this engine...but then due to common oil pressure/viscosity related issues with VCT solenoids & cam phasers, ford later officially supported anything between 5W-20 and 5W-50. Many ford 5.0 owners that have switched away from 5W-20 to higher viscosities such as 5W-50 say that their truck has never ran better...and especially in hot weather climates.
I originally planning on refilling the newly rebuilt engine with Valvoline Restore & Protect 5W-30 in order to help continue the internal cleaning process. However after more research I'd really like to run 5W-50 in the engine due to the way the higher viscosity affects the timing components, and due to its additional protective nature in hot weather...as I live in south Texas where its regularly 95-100 degrees with 85% humidity for many months (tropical environment)...and mild winters that sit between 30-70 degrees and only last for a few months.
Here's my thought/question: Would it be ok to use a Amsoil 5w-50 during the summer months (to protect engine wear with the hot weather, to help timing components operate better)...then switch to Valvoline R&P 5w-30 during the winter months (to help continue cleaning)? Would changing brands & viscosities cause any problems?
I wish Valvoline made a R&P in 5W-50...but they don't.
Thanks!
Wristcheck
Great job cleaning the massive amount of sludge buildup. Do you know what area and how the truck was used before you purchased it?
My exposure to extreme sludge build up causes are as follows:
- Poor PCV system designs
- Short trips in cold weather
-Coolant leaks into crankcase
-Neglected oil changes and low quality oil
My Great Uncle had a 1985 Oldsmobile 88 (last of the RWD) with a carburetor fed pushrod 305 V8. Low mileage 5 year old car under 8,000 miles at the time I visited him. He retired in Clearwater FL and did not drive much with trips shorter than 5 miles round trip. The key sludge builder, I suspect, was he would start up and idle the engine 2 to 3 minutes ever day thinking he was doing good. (as expected he often had to hook up a battery charger to keep the battery charged). My Mother inherited the car years later and we pulled the RA cover to see extreme sludge buildup. We then took the oil pan, the other RA cover, timing chain cover and cleaned as best we could; changed the PCV valve and started frequent oil changes. No engine issues later.
