I've run the numbers on the Lucas stabilizer, which is basically a thickener. You are slowly destroying engines. If I remember, it took a 10W-40 to a 20W-50 on a normal capacity engine. So you are getting very poor lubrication and high wear on every startup, at every temperature.
And running a diesel oil in a gasoline engine will destroy modern catalytic converters. By API rules, you can tack an SN or SP onto the end of any diesel formulation that meets the wear and other characteristics, ignoring the high phosphorous content. This sort of makes it ok for fork lifts and other equipment. That is why it (even in a 10W-30 viscosity) will never have an ILSAC starburst.
