I think you're backing up my statement about thinner oils working better?
No, I'm explaining a necessary caveat that needs to be understood when talking about "flow" at start-up.
I disagree that the engine is "fully enveloped" in oil when first started.
I didn't say that. Re-read the statement. You won't engage the relief unless the system pressure hits what's required, and that won't happen until the engine is full enveloped, if it happens at all.
The larger galleys are full, but the back pressure had built up before the thick oil can get through the smaller passages, such as splash/jet oiling of piston bottoms, valve train, etc. It will be "thrashing the oil with the pump" until it warms up enough to thin out (which may be by sheer oil friction), depriving the engine of much needed lubrication on start-up.
You are missing it.
The pump will only be thrashing the oil by sending it back through the relief, if the system pressure is high enough to do so. This happens only after the engine is fully enveloped, if it happens at all. That's why I provided an "extreme case" example, which you don't appear to have properly processed.
An engine designed for 30 oil is designed for 10cSt viscosity. In a perfect world, oil would be at 10cSt at all temps, but, alas, it's not. The 0w-30 I have mentioned has a 40C vis of 57.1cSt, so it doesn't have far to go to get to the desired 10cSt. So if it's 104F outside, the 0w-30 is at 57.1cSt.
No engine is designed around a single grade of oil. They are designed to be tolerant of a wide range of oils, with the thinnest safe grade typically recommended, for fuel economy. The important part is to not go below the safe range for that piece of equipment. As the years have progressed, and more effort has been put into chasing fuel economy, that tolerance for thinner and thinner oils has been pushed further and further, and changes to engine design, including special coatings, and wider bearings, have been necessitated to facilitate that.
My 6.4L and my 5.7L have the same bearing clearances, one specs 0W-20, the other specs 0W-40. The difference? The 392 rev's higher, is expected to be tracked, and makes 74HP/L, vs 69HP/L for the 5.7. Ford famously spec'd 5W-20 and 5W-50 for the SAME ENGINE, depending on whether the car was sold with the "track pack" option or not. The track pack got an oil cooler and a highly modified or completed omitted oil temperature neutering system (this was never clarified) which would significantly reduce the power output on the 5W-20 spec cars once oil temp got sufficiently high.
While I appreciate efforts to simplify things by trying to put them in these tidy little boxes, it's never that easy unfortunately.
The BBC has an "RV" cam with power range of 1500-4400 RPM, so not too radical. My thought is the Higher ZDDP would be beneficial even if it's not so stressed.
What are the spec's on it though? Does it have aggressive ramp rates and high lift or is it just generally pretty mild overall?
Timing chains also stress oil,
That is primarily brought up when we are discussing SOHC and DOHC engines with 6 miles of timing chains, not a pushrod engine.
so I'm wondering if there'd be a benefit there, as well as leaving a protective coating to protect during start-up before the cold thick oil can reach it. Even with a roller cam, would there be benefits to extra ZDDP levels?
All oils are going to leave a protective coating. I generally lean toward the full-SAPS phosphorous levels of 900-1100ppm. There's no mandated compromise in this area, so these levels are chosen because they are optimal, not because they are mandated.
I'm not too keen on a 10w-30, but that's the thinnest they offer. Both of these vehicles are in Texas now in a non-emission county, so cat protection is a non-issue. Yes, I know I should be more concerned with high temp operation, but as I stated, even at 104F, 0w-30 is still 57.1 cSt.
That visc figure doesn't matter unless you are on the relief, as I noted. What pump do you have in the engine? What's the relief setting? Are you hitting that pressure?
Adding too much ZDDP has been found to have the opposite effect on wear. I read of a test where aftermarket ZDDP additive was added to cheap oil, & it actually showed an improvement. But when it was added to a high quality oil it actually showed a decrease in wear protection. I would presume (hope) Amsoil formulates the Z-ROD correctly, not just boosting levels as a selling point.
That's a problem with adding anything to a fully formulated oil, the odds of making it better are always approaching zero.
Without having any real data on the build details, I'm hard pressed to recommend anything. I'd probably be inclined toward a 5W-40 personally, because it's old American iron. I typically run 0W-40 in my Windsors, but I am running 5W-40 D1 in the 351W in our boat, but it spins higher than your BBC does (though not often).
