Toyota 0W-20 in 2012 Jeep Grand Cherokee?
Iowa
A friend of mine just traded a RAV4 in on a new Grand Cherokee. He has $200 built up on his Toyota rewards credit card that they said he could use in their parts dept. He was considering stocking up on oil to use in his Jeep but the local Toyota dealer only carries Toyota 0W-20 in full-synthetic (he is strictly a synthetic user, won't even consider dino.) Does anyone see a problem with him using 0W-20 in his Grand Cherokee (spec'd for 5W-20)? I told him get onto some user forums and he might find others have done it without issues or even that Jeep had back-spec'd it, but I thought someone here might know off-hand.
I wouldn't run it during the warranty period. He should just look in his OM. The OM states: Engine Oil Selection For best performance and maximum protection for all engines under all types of operating conditions, the manufacturer recommends engine oils that are API Certified and meet the requirements of Chrysler Material Standard MS-6395. Engine Oil Viscosity – 3.6L Engine SAE 5W-30 engine oil is recommended for all operating temperatures. This engine oil improves low temperature starting and vehicle fuel economy. Engine Oil Viscosity – 5.7L Engine SAE 5W-20 engine oil is recommended for all operating temperatures. This engine oil improves low temperature starting and vehicle fuel economy. NOTE: Vehicles equipped with a 5.7L engine must use SAE 5W-20 oil. Failure to do so may result in improper operation of the Multiple Displacement System (MDS). Refer to “Multi-Displacement System” in “Starting and Operating” for further information. Lubricants, which do not have both the engine oil certification mark and the correct SAE viscosity grade number, should not be used. Synthetic Engine Oils You may use synthetic engine oils if the recommended oil quality requirements are met, and the recommended maintenance intervals for oil and filter changes are followed.
Isnt this an oil site? Either 0w & 5w -20 multigrades are SAE 20 weight. If you cant use a 0W then you cant hot start the car either as the oil will be too thin. Not an issue. Period.
Not an issue mechanically. The issue is in maintaining his friends warranty. For the 5.7l his friend has, he must use oil that meets three requirements to maintain his warranty: 5w20, API certification, MS6395 certification. Period. From the manual of my Charger: "MAINTENANCE PROCEDURES The pages that follow contain the required maintenance services determined by the engineers who designed your vehicle. Besides the maintenance items for which there are fixed maintenance intervals, there are other items that should operate satisfactorily without periodic maintenance. However, if a malfunction of these items does occur, it could adversely affect the engine or vehicle performance. These items should be inspected if a malfunction is observed or suspected." "Engine Oil Selection For best performance and maximum protection under all types of operating conditions, the manufacture only recommends engine oils that are API certified and meet the requirements of DaimlerChrysler Material Standard MS-6395." Notice how they even bold the word "required".
Technically being a synthetic oil it will be a superior lubricant choice to the specified 5W-20 dino. As RamFan points out, the issue in the very unlikely event that something happens to the engine, is that the oil hasn't been certified by Chrysler (MS-6395). But I don't believe Chrysler insists that you use their oil just that it be API certified. Just thinking out loud here, but does M1 0W-20 meet the Chrysler MS-6395 requirement? Mobil says you can run M1 0W-20 in any 5W-20 application without voiding the manufacturers warranty. Since Mobil makes the Toyota 0W-20 you may have the weight of XOM behind you in any warranty dispute.
The use of the word "required" seems to be in reference to the service intervals, where as the MS-6395 spec is "recommended". This is the EXACT wording in my Ford manual with regard to the Ford spec. It recommends the WSS spec, but only "requires" the API certification. Obviously, it's his call, but personally I used the Toyota 0W20 while still under warranty--and it didn't concern me in the least. Of course, I never had a warranty claim, either.
In certain engines toyota 0w20 with its extremely high VI and high level of certain additives can cause more deposits than some other 0/5w20 oils. I think it would most likely be ok but I'd probably use something else. you can always buy the 0w20 and trade it to someone.
Originally Posted By: LeakySeals
5w30 dealer bulk for my Pentastar so far, quiet as a mouse on startup.
Aw Jeez, now you did it! Dealer bulk oil? she`s done for now!jk
Which engines? Which additives cause what deposits? Evidence?
Toyota service 0w20 oil is no longer 0.1% HIGH MOLY, IIRC. Oui? I dislike paying 7+ bucks a qt for Idemistu Subaru SM oil, but it runs so nice in the subie, I'm stickin wid it. Since I bought a case I hope it works well in the Honda Too.
Originally Posted By: KCJeep
Dumping anything labeled Toyota into a Jeep is just wrong! laugh
Funny, but I have to agree with you.
Well if it makes you feel any better, as I mentioned it's made by Mobil for Toyota in the good old US of A.
The dealer might make your friend take a polygraph test. The service manger might accost him and pistol whip him till he talks. They have been known to do that if they suspect you put 0w20 instead of 5w20. If i was him Id get a bodyguard before he went in for warranty work.
Nope, it doesn't! laugh laugh
I agree. Since Toyota's reliability record is superior and Jeep's is abysmal, one should not waste quality Toyota parts trying to bring a Jeep up to average. laugh
