Originally Posted By: hone eagle
not the floor mats
As many have posted ,why didnt he..............??????
I've said it too,it cant be just the mats they have had this run away with no floor mats installed .
Electronic throttle,no neutral at WOT and no brakes if you drag them even for a bit.
The poster found NO brakes at WOT after 2 tries
Algothum issue for sure.
i beg to differ ...
the floor mat slipped OVER the accelerator pedal and UNDER the brake pedal
when the driver mashed the brake to the floor, the floor mat prevented full application of the brake, but also forced the accelerator to the floor ... WOT
this is driver error, not a software problem
the driver effectively had the go pedal floored, and the EFI at WOT
depressing the brake was the equivalent of flooring the Lexus, and he glazed the brakes
there is no underlying defect because the power needed a three second push, because manually shifting to Neutral would have solved his problems
and he could have braked and steered to safety with the transmission disengaged from the motor
tragic story indeed, but there are no bogeymen here
the simple explanation is the true an accurate explanation
occam's razor my friend
Toyo doesn't need a new algorithm ... drivers need to understand the function and very definition of Neutral
