Are you a chemist? Your equivocation of two different statements is troublesome to me. OP should try Kreen.The base of calcium sulfonate is calcium carbonate. It's in a different form but performs the same function. Same with magnesium.
I started this thread back in January. It’s improved a lot since then.Have you tried a 15w-50? Does that lower the burn?
Read GM service bulletin TSB# 10-06-01-008M:I’ve posted a couple of threads about my 2009 Scion with the oil burning 2az-fe engine so I won’t elaborate here and just jump straight to the question. What oil and change interval would you use if you were trying to flush out your oil control rings? I was thinking a synthetic 0w-20, but that’s mostly because I have a few bottles of Harvest King I don‘t need. Maybe a couple of 2000 mile changes and then reasses?
The engine specifies 5w-20 or 0w-20. I know Royal Purple has a lot of detergents so maybe a jug of it to start?
It should be, since it's called UltracleanCastro GTX Ultraclean?
Check out the VOAIt should be, since it's called Ultraclean
I would do the job right mechanically. But AFAIK, HDEOs are better fit for this task.would you use if you were trying to flush out your oil control rings? I was thinking a synthetic 0w-20
How does a VOA show an oil has better cleaning vs not?Check out the VOA
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4507347/
That’s a few years old but if it’s still the same it looks impressive.
For me it was the high Calcium levels. Calcium is a detergent. Typically it's around 1200ppm but in the Ultraclean VOA it's 2451.How does a VOA show an oil has better cleaning vs not?
Detergents don't really "clean", their forte is keeping things clean by neutralizing acids and preventing particulate and contaminants from plating out. They work with dispersants, which prevent agglomeration, which of course can also lead to them falling out of suspension.For me it was the high Calcium levels. Calcium is a detergent. Typically it's around 1200ppm but in the Ultraclean VOA it's 2451.
Okay, cool. Good to know.Detergents don't really "clean", their forte is keeping things clean by neutralizing acids and preventing particulate and contaminants from plating out. They work with dispersants, which prevent agglomeration, which of course can also lead to them falling out of suspension.
For actual cleaning, you need AN's or esters; something polar that can actively work to free deposits from surfaces.
That’s my understanding as wellFrom what I’ve read here at BITOG I’d be inclined to go with Mobil 1 0w30 or 0w40
Right, but you can't see any of the base oil blend.Okay, cool. Good to know.
So let me rephrase that then. It's called Ultraclean and it advertises: "Its double-action formula has been proven to clean away the sludge that can block engine oilways* and helps prevent new sludge formation". What stands out in its VOA is much higher than normal Calcium, which is a detergent.
I was a chemist. Your statements were factually wrong, whatever their intentions. That is all. Have a good day.What do you mean? A high based calcium sulfonate detergent additive contains calcium alkylbenzene sulfonate and calcium carbonate basic salt with the formula [R-SO3]2Ca(CaCO3)n. Same with magnesium. The root is the carbonate as the neutralizing agent. My statement is an attempt to simplify the function of the calcium and magnesium that shows up in a VOA/UOA. Perhaps a bit too oversimplified.
I am not a chemist.
