Before the market was flooded with fuel additives, Berryman B-12 was the go-to for unsticking piston rings, trickled down carb throats. Quick and dirty usually isn't the way to go, but if you're pressed for time....
I’ve posted a couple of threads about my 2009 Scion with the oil burning 2az-fe engine so I won’t elaborate here and just jump straight to the question. What oil and change interval would you use if you were trying to flush out your oil control rings? I was thinking a synthetic 0w-20, but that’s mostly because I have a few bottles of Harvest King I don‘t need. Maybe a couple of 2000 mile changes and then reasses?
The engine specifies 5w-20 or 0w-20. I know Royal Purple has a lot of detergents so maybe a jug of it to start?
I’d go with this:
High Performance Lubricants Engine Cleaner
Since the topic has come up a few times I am posting the PDS in the PCMO, Diesel, and Euro sections. This is a safe path to clean varnish and or sludge left behind by other oils. There are no solvents in this oil. It has enough ester to clean but still be safe with elastomers. Simply add a quart...bobistheoilguy.com
Royal Purple is a copycat of Valvoline with some purple dye.
If you want cleaning power, don't look at detergents. They're important for neutralizing and isolating sludge that gets kicked up into suspension, but they don't really clean per say. Detergents (detergent inhibitors) are acid neutralizers in the form of calcium and magnesium sulfonate which is found over the counter at pharmacies under the names Tums and Milk of Magnesia. The same way they neutralize acids in your gut that cause heartburn and indigestion, they neutralize acids in the oil that cause oxidation and corrosion. They exist more to keep the oil clean, not clean the engine.
If you want cleaning power, you want an oil with a good bit of ester. High Performance Lubricants has a cleaning oil that's ester based and replaces 1 quart in your sump for a short OCI.
If your oil consumption is due to coking or stuck rings, some extensive cleaning may help. However, if the consumption is due to worn rings, no amount of cleaning will stop it.
So what’s the end game here? Clean it, it possibly improves, then it gets bad again because of the oil control ring holes and you’re back at step 1.
But that’s likely not the case….the engine series in this car has a historical issue with the oil control rings…If the consumption is caused by oil coking due to the evaporation of inferior oils around the rings, causing the rings to stick in their grooves and not seal properly, then using a good cleaning oil can help clean up those deposits and free up the rings. If this happens and consumption slows or stops, then continued use of a better oil will help prevent it from coming back. If you return to the inferior oil that caused the coking/stiction, then it may come back. Some engines are more prone to this than others, but a good oil with low volatility and high in anti-oxidants will help prevent it in any case.
That's IF this is the issue. One way you can tell is oil coking usually won't be isolated to just one cylinder. If you pull the spark plugs and notice oil deposits on all of the plugs, then this is a probably cause. If you pull the plugs and find oil deposits heavily on just 1 plug with the others looking clean, then it's more likely a mechanical issue isolated to that one cylinder.
We also can't rule out the possibility of a valve seal leak. If that is the issue, then the HPL cleaning oil can still help as esters will condition seals and make them more pliable which could slow such a leak.
Seafoam is not a great cleaner. It's mostly a light pale oil with mineral spirits. It flashes off very quickly. A dedicated cleaner producing that uses esters is more effective and much lower risk.How bout seafoam treatment then following a 3-5k oil change using whatever you can get priced right
DITTO!!!!!I’d go with this:
It’s the oil control rings. It’s not the PCV (I replaced it) and it’s not the valve guides. I already know these things. I just want to know what’s a good oil to keep it clean or maybe clean it up a little more.
What cleaning agents does the oil have that a) will clean an already dirty, contaminated engine and b) that other oils don't have? What do you mean when you say it "is a very stout oil." What makes it more "stout" than other oils?Chevron Delo XLE 10w30
It is inexpensive and is a dual rated HDEO that is also API SN PLUS certified for gasoline engine usage. It has a ton of cleaning agents in it and is a very stout oil. I am using it in my Hyundai GDI engine that is one of the dirtiest running engines I've ever seen to mitigate that inherent issue.
