Biggest benefit is walking into Wally and buying ESP 0w20 for $28. While your there grab a Mobil 1 filter for one stop shop.Understood, but is there perceived benefit over 0w16?
While true, I mean on the aspect of how much greater performance.Biggest benefit is walking into Wally and buying ESP 0w20 for $28. While your there grab a Mobil 1 filter for one stop shop.
Yes, next question.Understood, but is there perceived benefit over 0w16?
Besides the MOFT headroom, ESP carries some of the most stringent approvals and specs. out there. Great base oil blend as well for engine and piston cleanliness among other benefits.While true, I mean on the aspect of how much greater performance.
I’ve been debating going to ESP x2 0W-20 for the RXh and a Subaru I maintain. Currently, the Subaru - 2019 Ascent, FA24F gets ESP 5w30, the RXh gets vanilla Mobil 1 5w30. I have Mobil 1 Hybrid 0W-20 on deck for the next OCI.Besides the MOFT headroom, ESP carries some of the most stringent approvals and specs. out there. Great base oil blend as well for engine and piston cleanliness among other benefits.
I’m using ESP 0w30 in a range of domestic, asian, and euro vehicles I own or maintain. Hard to beat IMO.I’ve been debating going to ESP x2 0W-20 for the RXh and a Subaru I maintain. Currently, the Subaru - 2019 Ascent, FA24F gets ESP 5w30, the RXh gets vanilla Mobil 1 5w30. I have Mobil 1 Hybrid 0W-20 on deck for the next OCI.
My reasoning for ESP 0W-20? It meets API SP, and has Mercedes 229.72/Porsche C20/VW 508.00 and 509.00/dexosD approvals. It seems to pull above a “standard” ILSAC/D1 0W-20.
0w-20 you need API SP or newest is SQ (backward compatible) and ILSAC GF-6a. On 0w-16 it's all the same but it will be ILSAC GF-6b, these are USA specs, I don't know about the JASO stuff.On the quest for 0w16 or 0w20 oil, I cannot find any that are JASO GLV-1 rated? Is that because that rating is for the 0w8 oils only?
TGMO 0w16 and 0w20 is only API certified, unless Im blind as a bat lol
It’s the standards for the ultra low viscosity oils likes 8 and 12.On the quest for 0w16 or 0w20 oil, I cannot find any that are JASO GLV-1 rated? Is that because that rating is for the 0w8 oils only?
Your link above seems not to work so thanks for the summary.Milky oil in pan.
#2 piston completely clean from coolant.
Guesses included failure of electronic temperature controls.
There were some quality control problems in certain other areas with early (~2018) A25A-FKS engines.
These showed up from time to time.
Per mechanics comments at YouTube.
Sorry about that.Your link above seems not to work so thanks for the summary.
Anything can fail. Did it say how many miles?
Given the number of them out there, and the number over 200K already (including here on this board) I think there proven.
Probably 10k oil changes…Looks like, at least from what I can tell, that the oil control rings might have been clogged on a few cylinders there, may have caused some of the bore scoring.
If only we knew exactly what the maintenance plan was.Probably 10k oil changes…
At least on this one, my 2025 A25A-FKS, it does have an electric water pump. The oil pump is not electric, but I think the oil temp is monitored, not even sure of that. I do know the engine coolant temp is up to operating temp FAST! I start the car in the garage, back out and head down the street, within 2-3 blocks the water temp is up to mid-range operating temp. I have been warned that if it ever starts to heat up, stop immediately, not 20 seconds from now, park, shut it off, and call a wrecker. It has something to do with the electric water pump. I think they can be damaged quickly from engine overheating from a failed electric water pump. I watched the video posted here, I think he said that engine had a little over 100,000 miles on it.If only we knew exactly what the maintenance plan was.
I am always searching for a bulletproof engine with an airtight oil and OCI in play.
My guess is that the mess on some of those rings lead to the clearly illustrated scoring.
The coolant in the combustion chamber followed as evidenced by the clean piston and the "frappacino" in the oil pan.
One mechanic stated that ~ 2018's had electronic oil pump, electronic thermostat related failures.
Viscosity ?
Oil quality ?
Length of OCI ?
We can call this an outlier, pointing to more recent model years.
Input welcome, friends.
Did not mean to hijack.
Thought this was very relevant.
