Toyota 0w-20 Motor oil, how good?
Victoria , Australia
I have just purchased a 2026 Toyota GR Corolla. The dealer will use Toyota 0w-20 motor oil at the service intervals. I was going to ask them to use Amsoil Signature Series 0w-20 but not sure how that "may" effect warranty.
Question...
Who makes the oil for Toyota? Is it a decent oil?
Thanks..
My 2016 Lexus es350 which now has almost 108k miles has been running on Toyota genuine 0w20 since brand new. It got oil changes at the dealer every 5k miles religiously from the previous owner since day one.
The inside of the valve cover is spotless. Zero varnish, no sludge. Engine does not consume any oil or leak any.
TGMO 0w20 is made by Mobil 1.
My local Toyota dealership has the 0w20 at $3.86 per quart. It’s an amazing deal, but I’m going with Mobil 1 ESP 0w20 on my next oil change.
No ... It spec,s 0w-20 only..
I would run 0W20 that Toyota wants, which would be API SP I guess. You don’t have to run TGMO.
After warranty, move to Euro approved oils, particularly MB229.5 or MB229.51/52.
Toyota will bend backwards to refuse warranty. They refused warranties on those Corolla’s bcs. they were driven above 85mph.
Here's a link to the Toyota of Mexico website: https://www.toyota.mx/propietarios-...-tu-auto/#tabs-6478e6d6a3-item-2fa521cc7f-tab and the Toyota website in the UK says, "
Engine oil selection
“Toyota Genuine Motor Oil” is used in your Toyota vehicle. Use Toyota approved “Toyota Genuine Motor Oil” or equivalent to satisfy the following grade and viscosity. Oil grade: 0W-20, 5W-20 and 5W-30: API grade SP “Resource-Conserving” or ILSAC GF-6A multigrade engine oil. Recommended viscosity (SAE): SAE 0W-20 is filled into your Toyota vehicle at manufacturing, and the best choice for good fuel economy and good starting in cold weather. If SAE 0W-20 is not available, SAE 5W-20 oil may be used. However, it should be replaced with SAE 0W-20 at the next oil change." Source: https://www.toyota.co.uk/customer/manuals#/pdf/PZ49X-18144-EN?modelType=GR 86&lineOffDate=2022-06-15
Ed
