History: I've been driving only Hondas (Civics mostly) for the last 30 or so years, whenever Honda switched to 0W-20, I went to Mobil1 0W-20 AFE and their M110 filters, usually changing between 5-6K/miles, never had an issue, Blackstone UOA'S were always predictably excellent. Now, we have 2 2020 CRV'S, mine is has about 14K on it, just did a UOA and it was ok, but the Fuel % was 1.3 and the SUS and cSt viscosities were below value. Wear metals were also a bit higher that average overall. Apparently the CRV is a bit harder on oil than the Civic, but both use, essentially, the same engine, but the CRV has higher output, and a heavier car. Considering some changes, and as the M110A filters have changed manufacturers and are, probably, somewhat lessened in quality, am considering either the WIX 57356XP or NAPA 47356 (believe these are the same). Also considering changing to Mobil1 0W-20 EP, also have been looking at Penzoil Platinum and Platinum Plus (hard to find locally) as well, but have heard about some NOAC value issues with them. So, it's change time. I'd appreciate any opinions based on experience, my inclination is to try the Mobil1 EP and either of the WIX made premium-level filters. You collective wisdom and experience over the years has been very appreciated. I'm sure these are common questions, so, flame suit on, fire away!
