- Joined
- Aug 13, 2023
- Messages
- 20
Honestly not trying to stir stuff up, just hear me out.
Regardless of the oil brand or duration, most of the 'I sent my oil in for analysis' posts result in the same conclusion: "I could have gone longer." So, I simply ask, why not?
My last car was a 2001 BMW 330xi and I had it for 14 years. I used to only buy dealer oil ("nothing but the best for my baby" type thinking) and Mann oil filters, when BMW switched their oil supplier I figured "if they can switch, so can I," and went to Mobil 1 0W-40 Euro because it was LL-01 approved. Some time ago that Mobil 1 oil lost the LL-01 certification, I didn't know what to do so I just kept using it.
My 330xi took SEVEN QUARTS of oil, so I was completely fine with longer OCI. The oil service minder reset at 15,525 miles. Since the car took so much oil I changed it every 10k. Later on I just drove it until the car told me the oil service was due.
Now I have an Acura TL (4.5 quarts). I've been using Mobil 1 Extended Performance 0W-20 and Fram Ultra Synthetic filter, replacing when the oil service minder goes off at 9,000 miles. Both the oil & filter say they're rated for 20k miles. Heck, even the user manual calls for changing the oil filter ever other oil change (I do it every time).
This has me wondering. I know a lot of you are changing at 5K, some are crazy enough to do it at 3k because it's still 1975 in your garage. What's really wrong with going 10k, 12k or 15k on the oil/filter if the manufacturer says so and so does the oil analysis places (I've seen some 15k high mileage OCI analysis has had Blackstone noting to try even longer...) say it's okay too?
What flared this up was some recent deals I've seen going on:
$24.29 5qt Mobil 1 Extended Performance 0w20 (Sold as 3 pack @ $72.88)
$22.29 5qt Mobil 1 Advanced Fuel Economy 0w20 (Sold as 3 pack @ $66.88)
$15.50 5qt Kirkland 0W-20 (Warren Full Synthetic sold as 2 pack @ $30.99)
$14.48 5qt Pennzoil 0W-20 Platinum (Not Ultra, after $25 rebate shenanigans buying 2 pack @ $26.98 each)
If I really drill down, the math is crazy:
For the cost per mile to be the same it'd be 14,100 miles on Mobil 1 Extended Performance vs 9,000 miles on Kirkland/Warren. I'd wager just about everyone here would rather use Kirkland/Warren and change at 9,000 miles, right? Even still, maybe going longer on Mobil 1 Extended Performance would have me changing the oil less often...
So I figured, all things considered, if I kept changing every 9000 miles, does it even matter what I use? Why not go longer?
Any thoughts other than "oil cheap, engines expensive, ooga booga!"
Thanks for coming to my Ted Talk.
