johnmyster
You'd use 5w-20 FS over a comparable 0w-20? I'm being genuine here. Please enlighten me.I'd probably go with PP 5W-20 or Mobil 1 5W-20.
It's available at NAPA and ADVANCED AUTO . Too expensive at this time at NAPA . A.A.P. has it for $41.99 for 5 quart jug , so $8.40 a quart . I think the rebate for PENNZOIL is possibly in March or February. OXIDATION for PU. 5w-30 is 10.1 .
I would in a climate that isn't very cold. You don't need a 0W for cold starts in your climate. Like I mentioned, a 0W-20 normally contains more VII, which contributes to valve deposits. This assumes that the two oils use similar base stocks.You'd use 5w-20 FS over a comparable 0w-20? I'm being genuine here. Please enlighten me.
MB 229.51 apparently now includes an LSPI test, but I'd still be wary of using an oil that has a lot of calcium. Higher-calcium oils can still perform okay in LSPI tests if they have a lot of ZDDP and moly, but calcium is by far the most important factor.Moreso, even after reading the hotly debated threads on the topic, I'm not assured that the MB229.51 or LL-04 spec is/was intended to offer as much (or any) LSPI protection as SP, Dexos1, etc. The VOAs for out there for it pretty much show mid Ca and Zn/P, and nothing more. Moderate B, no moly. I'm just not easy drinking the euro kool aid for this GDI application.
I'd use a FRAM Endurance. It's got a thick can, and doesn't have the corrosion issues sometimes seen with the other FRAM models like the Ultra, so it's a good choice for a filter that's going to stay on the car for a long time.3) I'll probably change to a top shelf 7317 style filter, and run it multiple intervals. The mazda value filter I've always used has gone up to $7, has no ADBV, and probably isn't much of a filter. 75% of the mess during oil changes is dealing with the filter. Make that mess once every 12-18 months.
This is mind, then any lube with a good detergent package and low NOACK score will suffice.... IVD is the principal concern.
That should be no problem; see above. (By limiting yourself to this, you are excluding Amsoil, HPL, etc.)Walmart jug oils are strongly preferred.
No current leader; not that we BITOGers would be easily able to distinguish. There will always be slight differences, but none that a typical application would see manifest into either certain destruction or assured infinite life of the engine. Hence, see my first comment at the top.Between M1-EP (HM or non), PP (HM or non) and the other variants (M1 AFE, M1 AP), Castrol, Valvoline, etc, is there a current leading candidate for IVD and LSPI?
Minor nuances perhaps at most, but generally nothing that you're going to discern in your use.Amongst a given brand and model of oil (M1 EP or PP, for instance) would grade choice (ow-20 vs 5w-30) contribute to NOACK, oxidation, IVD, etc?
Bottom line is this ... There are some reasonable assurances in the industry to address your concerns of IVD and LSPI. Look for lubes that are licensed for GM's Dexos and API SP (or, lubes with a well-proven pedigree that would "meet/exceed", but which may not be licensed).
I don't feel like SOPUS has put much effort into developing PUP. It looks a lot like PP on the PDS. And why would they? They don't sell much of it. I'd steer more toward PP if I was a Pennzoil guy. I think all their marbles are put into that product because of its sheer volume and stature in the marketplace.PUP is very good oil but Mobil 1 EP would probably out-perform it.
How’s your JLU ? Have you had the oil cooler leak ?I don't feel like SOPUS has put much effort into developing PUP. It looks a lot like PP on the PDS. And why would they? They don't sell much of it. I'd steer more toward PP if I was a Pennzoil guy. I think all their marbles are put into that product because of its sheer volume and stature in the marketplace.
As for M1, that is my go-to.
I think the same way. Ease of acquiring is a huge bonus. I need a VW502 oil and I've yet to see a Walmart that didn't carry either Castrol 5w40 or Mobil 1 0w40 so I always use one of those two.Never seen PUP at the local WM, so unless there's a deal on amazon during a rebate, I'm biased against it. Is it so great that I need to reconsider?
PP and PP-HM are fair game.
Wasn't there some test where M1EP bigly outperformed PP, PPPP, and PUP on oxidation?
It´s doing great! 91k miles and did its 3rd trip to Moab in October. Probably the hardest wheeling it has done, next to a trail in New Hampshire.How’s your JLU ? Have you had the oil cooler leak ?
Awesome - keeping mine a while as well - I use a T handle on the filter and nobody else has touched it … No guarantee - but that helps IMO … Just a sand and mud guy - but things get beat up by the Bubba’s with 98” tires - so figure shocks will go first …It´s doing great! 91k miles and did its 3rd trip to Moab in October. Probably the hardest wheeling it has done, next to a trail in New Hampshire.
No oil leak. I did have to replace sensor seals that were seeping a very light film of oil probably 30k or 40k ago, but it was under warranty. No big deal. But I have been very careful with that filter cap torque, too.
She´s on course for a long life!
Nice, where did you get the Tee handle? I may scratch one of those up today!Awesome - keeping mine a while as well - I use a T handle on the filter and nobody else has touched it … No guarantee - but that helps IMO … Just a sand and mud guy - but things get beat up by the Bubba’s with 98” tires - so figure shocks will go first …
https://www.walmart.com/ip/Felo-T-H...ck&expiryTime=1708357813627&c=mWebSmartBannerNice, where did you get the Tee handle? I may scratch one of those up today!
