been lookin for a set, i quess they are not on the preferred list from searches!!
Searches? What preferred list?
I've changed that exact filter. I'm not sure the linked stubby set will help.Dang - how topical. I need a 4mm stubby 1/4 drive to get into a weird place (and will need in the future). I have googled this and found nothing.
I need it to get to the filter housing on a Volvo's Haldex AWD unit. The alternative is to remove the exhaust, then the drive shaft. THEN, pull the awd unit's input flange with a gear puller. Yay - what intelligent design. I was able to get one car serviced with tedious work with a 4mm allen wrench, but no luck on this one.
I hate buying "one-off" tools but Volvo made this a mess, so I guess it's going to happen.
This is the mess they made:
Has VIM stepped up their game Paul?? I had a set that I bought @20 years ago & in the Hot Rod world I ran across a lot of stainless Allen headed hardware that would chew up VIM bit sockets like candy where Snap-on bit sockets held up really well.
A couple years ago I was searching for stubby 7/32" to adjust the band on a powerglide transmission while in the car, and Blue Point is also where I ended up.Chris, they seem to have at least with these little ones, I only have these and the Torx stubby set from them but they are holding up okay.
I use them mostly for the front chain covers, they are all button head torx that no regular length bit socket can get into, Blue Point has them but they seem no better or worse and also Taiwan made.
