Just a heads up about EBC and euro pads.
Most euro pads had copper reduced or removed in 2020 due to regulation so they behave differently now.
that goes for all pads, not just Euro and EBC
I know - I will pick soon...Hawk, EBC, Akebono canr go wrong there.
There are smaller cottage pad makers like porterfield.
We are getting into "i want a specific brake behavior" category vs "oem or good enough"
I want to have it ordered before Monday - so, that it goes out (shipped whenever PA does their first shipment).
The EBC - I read they are semi-metallic? Anyway, the price on Amazon went up to $100 so they're out.
Are these good?: HELLA PAGID - 355035001 $50
They just appeared - so, I think it was out of stock but is available now. These or the Akebono ACT pads for $75?
I'll pick between these two today - and then order. The rotors I'm going with is the Power Stop JBR964EVC Geomet coated - I just can't pick a strange brand - I'm reluctant cuz I don't want a problem - or need to change the brakes early - A Premium, Brake-X and Tovasty - seem okay - and the 2nd one is made in Canada - but, I read mixed reviews - mostly good but some saying they had to change the brakes out early.
Yes, sir.Both are Ceramic, is that what you want/need up north with salt ?
Never heard of NRS. I also didn't see them on any site so I probably can't get them.Hey did you look into NRS brake pads and how much they cost compared to what you listed?
Also pagid? I think pagid makes a bunch of euro OEM dusty pads, maybe they make low dust ceramics?
I would look into akebono ASP line too its a bit more expensive but should last just as long and gets better performance according to Akebono.
Edit: also if you dont like brake dust go ceramic all around less dust. I think the red dust is just iron rust particles? Could be from the rotor or the semi metallic pads?
Correct - PA has the NRS pads for $67 plus tax. They are semi-metallic but supposedly quiet for that material?NRS brakes are made in Canada, in Ontario somewhere.
Link:
https://nrsbrakes.com/collections/all
Although I think their stuff is semi metallic.
Any way I think that Akebono is OEM for a lot of japanese car makers and brakes is the last thing I would be saving on.
Really?The Pagid pads seem to be worth trying. Pagid pads and Powerstop rotors should be a good combo![]()
I found Pagid Silver ceramic pads but not sure about them - are they made in Germany or India (or China)? I think that makes a difference.... if the latter, they're probably just like any other brand? These ones are cheaper than the Akebono so it's making me wonder.For German cars I use OE or Zimmerman for rotors and ATE and sometimes depending on COO Textar and Pagid for pads, the Bosch I have seen that other people bought and wanted me to install look like most of the other lower priced Chinese parts. Compare them side by side to made in Germany Zimmermans or OE and it is night and day.
