Valvoline R&P Oil Burner Test Results
Gasoline is the main culprit of the ring lands getting stuck because it fills up with carbon. Gasoline, especially low-octane fuel, is cheap for a reason: it contains very little to no detergents. Personally, I use a fuel system cleaner twice between oil changes, maybe more often. It seems to help. I would definitely keep using Valvoline R&P and also use some fuel system cleaner, maybe Techron High Mileage or something similar. Red Line SI-1 is very good. PEA has a tendency to clean those carbon deposits.
There are required federal minimums wrt detergents.
I'm 3000kms into my first OCI of VRP and it's wild when you start the two ATS's side by side. The 2017 with M1 0w40 is so much quieter on start. The 2014 sounds like a bag of ball bearings when starting it in comparison!
I'm going to perform an oil change and cut the filter open in the next 1000kms. Considering this car is 11 years old, and burns no oil that I could tell, I'm not expecting anything other than a feel good "why not clean her up" experience. It'll be interesting to see if the filter has anything in it.
I'll run 2 more OCI of 4-5,000 kms and then switch her over to 0w40 also.
Which engine in those two? I’ve got an LY7 3.6 in my 08 CTS.
I really don’t understand the mentality of using VRP as a cleaning regimen only. It’s seems ridiculous to me. Look at the UOAs of VRP. What oil at that price is delivering materially better UOAs?
People are acting like this stuff is MMO or some kind of sketchy cleaner that you need to abandon to go back to “real oil”. Well guess what, your “real oil” is the reason you needed VRP to begin with.
Remember , Valvoline claims VRP is their best oil period .
Low-octane fuel contains very little to no detergents is an interesting statement. Where did you get that fact from?
Interested to know this as well. I was under the impression that Top Tier, any octane level, has a good amount of detergents.
I too use fuel system cleaner, usually Techron about 500 miles before an oil change and top tier ⛽️. Chevron or Costco
The problem is that he's half-correct. Yes, low grade fuels are a contributor to piston ring issues. But it's not because there's "little to no detergents" in cheap gasoline. It's because even with the federal minimum detergency, it's still often inadequate. Of course, this is quite dependent on engine and duty cycle. There are duty cycles and engines for which no amount of detergency will suffice.
And conversely there are engines that, when used a certain way, can burn the sketchiest swill at a public pump and be OK.
Some premium brands, such as Shell V Power, claim to have their most potent additive amounts in the higher octane. Iirc?
Someone correct me if I’m wrong.
All of their fuels may be Top Tier, but their V Power supposedly has more of the goods.
Now, is it necessary to purchase 93 over 87 octane from Shell if the other grades are top tier?
I wonder if Costco does the same? I fill up there primarily. They tend to only offer 2 grades; no mixing of the two for a mid grade. 93 or 87. 🤷‍♂️
It was my understanding Kirkland Signature claims all their grades are “5x the minimum required” so not necessarily a special sauce in the 93 like at Shell or a Chevron.
I’m not sure where he got that info. I called BS. He’s no longer with us…
I believe his information lacked nuance and context, hence overly opinionated and lacking clarity. It’s not a true statement in all situations, even if it could be true in some contexts. Do premium octanes have more detergents than 86/87 unleaded? Maybe. Depends. That’s the harm with making blanket statements. Usually, it’s to cover insecurity without doing the work to dive into the facts. That said, I do believe in using a PEA containing fuel system cleaner once prior to each oil change. Can’t hurt.
I was lucky enough to have a top tier Mobil station near my house(also use Techron a couple times per year). I was unlucky enough to have turned wrenches at a time of cylinder wash and ridge reamers up through stuck injectors and poppet valves. GM was going through Techron by the barrel.
My ring deposits were not fuel related.
Top Tier gas plus Techron twice per year should alleviate gas deposit concerns on rings . Perhaps Redline SL-1 at a maintenance dose level or TCW-3 added to gas is an added measure to combat gas related ring deposits ?
Just passed 5k miles on my 4th and final oci of Valvoline R&P for a total of 20k miles. It’s been hard to keep my mouth shut but here are the details and results!!
2018 Subaru Outback that I bought new. Started burning oil right at about 60k miles. Before that it only used about a 1/4 quart in a 5k mile oci. It started using 1 quart in 5k miles and steadily increased to almost 3 quarts in 5k miles. I was adding a little over a quart every 2k miles when I started this test. I have done every service myself on this vehicle including the pcv valve on time. I’ve only used a couple high quality full synthetic oils at 5k mile oci’s since new. The internals have always been spotless. I used a borescope and found oil wash on 3 pistons confirming my suspicion of stuck low tension oil rings. Here are the oils I’ve used in detail.
500-35k miles M1 FS 0w40
35k-100k miles Valvoline EP 5w30
100k-110k Amsoil SS 5w30
110k-130k Valvoline R&P 5w30
Results with R&P:
1st oci=no change
2nd oci= no change(almost gave up)
3rd oci=added 1/2 qt at 2k miles, 1/2 qt at 4k miles! Used a little over a quart in 5k mile oci.
4th oci=added 1/2 quart at 3k miles and used a total of less than 3/4 quart in 5k mile oci.
So R&P has improved my oil consumption from almost 3 quarts per 5k miles to less than 3/4 quarts in 5k miles. Not 100% but not to shabby if you ask me. I highly recommend people give R&P a try for at least 4 oci’s.
My plan is to run M1 ESP 0w30 for the foreseeable future. I want to see if this oil will keep my piston rings as is. I will continue to update this thread with any changes.
Why not keep running R&P since it's doing so well? It may still improve. Also you were running excellent oils and the rings still got carboned up as has happened with a number of people on here.
Oh yeah...., Varnish is hard to remove. It takes time and even engine flush product won't remove it in a short time. Varnish is caused by oxidation from high temperature, Varnished surface is stickier than bare metal surface and can robe efficiency. It is very common to find varnish in engines that use mineral oil in their past.
I’m using this vehicle as an experiment for all here. Currently testing ESP 0W-30 to see if it will keep the rings clean. R&P is a game changer and probably covers 99% of drivers IMO.
