Forgive this basic question but I've been reading a lot about the Valvoline R&P and I'd really like to give it a try in each of my cars:
2011 Toyota Sequoia v8 flex fuel (290k miles): R&P 0W20 or 5W20
2006 Mitsubishi Evo (58k miles): R&P 5w30 + VR1 10W30
2022 Hyundai Veloster N (14k miles): R&P 5w30 + VR1 10W30
The Sequoia obviously has a ton of mileage, always used good oil but OCIs varied from 5k miles to 15k miles. I've only owned it since 220k miles, so not sure what maintenance was done before that. My question is, should I mix in a regular other oil so the cleaning isn't too "harsh"? I've seen some oil filters totally gunk up after using this oil - I'm happy to change filters often if necessary. Or am I overthinking it, and just run it? Or try only running it for 1k before flushing the system with more?
The Evo is raced (autox, track days, time trial - harsh usage) - I usually run VR1 or ZROD, but on the off season I'd like to try using R&P to do a little cleaning. I run E85 about 50% of the time, usually during the race season - will there be any issue going back and forth between R&P & VR1? R&P says it needs 4 flushes to clean 100%, but I don't know if interrupting it will cause any issues.
I mention the Veloster because while it's very similar (2.0L Turbo), it is direct injected (evo is port) and only runs 93 - but same question, autox/harsh usage, often short trips, thinking about using VR1 during the season and switching to R&P during the off season/winter (now).
Would I be introducing any complications by switching oils like this? I have to imagine no, I've run many different oils before, but wasn't sure if there was something special about the additives in R&P that would have need for additional consideraation.
