Let me preface this though experiment by stipulating that I understand the following:
1) R&P is not, or at least is not advertised, as an extended drain interval; let's assume a normie 5K-ish drain interval
2) R&P, currently, does not offer a wide selection of viscosities so if your vehicle requires a 0w40, here in the USA, R&P would be out; let's assume most cars require or recommend a 0w20 or 5w30 that R&P offers
3) R&P, currently, is not offered in the USA in Euro flavors
With those things stipulated, what arguments could be made that R&P is *not* a good consistent use/long term oil for most vehicles. At Walmart, it's part of the 5qt jug at approx $29 cadre, so why would one not select it. I'm making this argument in good faith; just curious if there is a reason it would not be the ideal choice for vehicles/use cases that don't fit the stipulations above.
