In my case the internals are spotless on 5k oci’s but the piston rings aren’t. OTC synthetics were up to the task in keeping sludge and varnish at bay but couldn’t handle the heat in the piston ring area. IMO it’s poorly designed low tension rings with mediocre “synthetic” oil that’s the bad combination. The race to produce a cheaper oil that meets not so stringent approvals, mostly based on fuel economy doesn’t always work(totally engine dependent).
My next test will see if using an oil with more stringent approvals, focused more on wear and engine cleanliness will be up to the task in my oil burner. It’s going to be a long test as it took 60k miles to start burning oil in the first place.
