Valve Cover Photos - 2016 Acura RDX w/161,000 miles
Amazing how under valve cover pictures of a clean well maintained engine is slowly turning into a thick vs. thin thread.
My wife's 2016 RDX has 128,000 miles on it with the same oil change regimen as yours. I haven't had the valve covers off to look, but I suspect it is just as clean as yours. I replaced the PCV valve a few years ago as a maintenance item and it was still working fine. Burns absolutely no oil between changes.
A question for the OP, were you getting any ticking or other symptoms indicating the need for the valve adjustment? My wife's RDX hasn't had them adjusted yet.
Looks very good. Looks likes one bank ever so slightly darker than the other. But, could be lighting. Muzzled or not?
....were you getting any ticking or other symptoms indicating the need for the valve adjustment? My wife's RDX hasn't had them adjusted yet.
I'm not the OP, but this question about "ticking" comes up a lot. My understanding is that noisy valves are perhaps too loose...which isn't harmful in itself. But the Too-Tight Valves are QUIET...and those clearances should be loosened. The reason is, too tight means they may not be seating well, allowing combustion gas to squeeze past the seat area...which heats it up. This can fracture the valve edges. So "ticking" isn't a good-enough indicator to give clues to whether clearances should be checked.
I love this post. The superb recordkeeping has silenced the vocal segment who proclaim that manufacturer recommendations are a conspiracy. I am scratching my head about a switch to ultra-premium oil so late in the game, after you have essentially proven that good oils do the job just fine. (personally, I like Mobil 1 a lot, but find it just slightly too pricy). These J-Series engines are built for starship mileage and best wishes for the next 160k.
First Valve Adjustment. I have performed almost every service since new.
Intervals have been every 7-8K per the OLM using 0W-20 synthetic. Zero oil consumption. Last two intervals have been HPL 10W20.
Engine is the 3.5L with VCM, engine code is J35Z2.
Oh my gosh! Those J35s are so terrible on oil! Your engine is going to explode at 8k intervals! 🙄
Very very nice. Probably the cleanest VCM engine I remember. 👍🏻
How do you know what’s been done over the last 20k? It could have not been this pretty prior to HPL. In all likelihood it was pretty clean anyways, but since OP didn’t check before the HPL we can only say “looks great today”.
  • Haha
Reactions: hrv
Yeah based on the multiple brands used it's pretty fair to say we can't conclude what oil kept it clean or not.
