After some discussions with @dnewton3 I have decided that I will continue to run this oil. The ultimate question is, how far can this oil be run before it reaches an ultimate condemnation and what will that condemnation point be? Some possible condemnation points could be:
[edit Jan 7, 2024] - The oil has been changed see this post:https://bobistheoilguy.com/forums/t...0-miles-on-hpl-hdeo-5w-20.377792/post-6745783
Previous UOA:
https://bobistheoilguy.com/forums/t...-300-miles-on-oil-173-000-miles-total.377756/
[edit Jan 7, 2024]
174k miles sump pictures taken after oil is drained
174k miles under valve cover pictures. I took these pictures about 5 minutes after engine shutdown, so there is still a lot of oil that hasn't run off the surfaces.
164k miles under valve cover pictures:
- Varnish deposits
- High viscosity from oxidative thickening
- Low TBN
- Rapidly increasing wear metals
Previous UOA:
[edit Jan 7, 2024]
Dodge Durango 3.6L 174k miles total 34k miles on oil - sump pictures
- wwillson
- 23
Bore scope inserted through drain plug hole taking a look around.
Under valve cover pictures - Dodge Durango 164,000 miles total
- wwillson
- 8
- 1
This engine has been running HPL 5w-20 HDEO for 52,000 miles
