Dodge Durango 3.6L - HPL CK-4 5w-20 - 33,300 miles on oil - 173,000 miles total
wwillson
Staff member
Colorado
This sample was pulled from my 2014 Dodge Durango with a total of 173,000 miles and 33,300 miles on the oil. I estimate the run time is 835 hours(33,300 miles/40 MPH). The oil is HPL's 5w-20 CK-4 based formula and has been run since Feb 9, 2022, about 23 months. The lab is Wearcheck. The usage on this 5,300 miles run was >75% high speed driving down the interstate. There was 3/4 quart of makeup oil. The PCV valve was changed and oil consumption returned to zero and the oil cooler was changed. Approximately 50% of the fuel used for this 5,300 mile was E-85. Fe wear rate for this 5,300 miles was 2ppm/1k miles. The TBN is still at 7.66 so plenty of alkalinity left. Without the makeup oil, we can extrapolate that the TBN would have been around 4.5, which is darn good for a run this long. Viscosity has increased to 13.2, which is well into the SAE 40 range (12.5-16.29). The Fe wear rate was almost exactly 1ppm/1k miles, which is outstanding.
I believe that this oil has reached it's useful life and will be changed. The condemnation limit of both viscosity and oxidation have been surpassed. @High Performance Lubricants suggests no more viscosity increase than 3 cSt, which is exactly where the viscosity is now. Wearcheck suggests an an oxidation limit of anything > 25, this oil is now at 27.1 (normalized).
[edit added Jan 6, 2024]
This is the oil filter run for the previous 5k miles. I was able to scrape agglomerated material off the filter, a 3cSt increase in viscosity, and normalized oxidation value of 27. The data is telling us that we have found the limit of this oil. The oil has been changed with 6.5 fresh quarts of HPL HDEO 5w-20 and a Fram Endurance filter. I will use the same methodology to determine how long the next run will be.
The air filter was changed with 43k miles of run time. The Si was ticking up during this OCI and it could be that the air filter had too much time. When I removed the filter, I noticed the clean side of the air box was not perfectly clean. Either this air filter let some dirt into the engine or the installer (me) didn't get a tight seal.
A bit of metallic material stuck to the drain plug magnet:
[end edit]
One of my reasons for running this oil out so far was to validate what HPL claims about their engine oils. The claim is that their oils are formulated for extended drains. When I asked David Ward how far can the OCI with these oils be extended? His answer was, "longer than you will be comfortable". Challenge accepted. I put all feelings aside and strictly used data from UOAs and took some pictures inside the engine to check the cleanliness. You have seen the results. In the future I will likely do a UOA every 10k miles, instead of 5k miles. I feel completely confident that I could sample at 20k miles and 30k miles, but will also sample at 10k, because I like data.
Fleets extend oil drains because they save money, which equates to making more profit. I am not a fleet, but did gain on several points. Why change oil when data shows it's not necessary? It seems like a waste of resources and money to throw good oil away. I do not really enjoy crawling under the car to change oil. I did save money by extending this OCI and will save more by reducing the frequency of UOAs.
When I change the oil, I will post more internal pictures taken with my bore scope.
Previous UOA:
https://bobistheoilguy.com/forums/t...-000-miles-on-oil-168-000-miles-total.375625/
Oil cooler change thread:
https://bobistheoilguy.com/forums/t...-oil-cooler-installed-on-2014-durango.375802/
Under valve cover pictures:
Sump pictures after oil was drained:
Data:
Sample Information
Sample DateFeb 2020Dec 2020March 2021August 2021October 2021February 2022March 15, 2022September 5, 2022April 19, 2023June 13, 2023October 28, 2023January 1, 2024
Machine Age miles116,000122,200127,420132,679137,615140,000141,500147,000152,000158,700168,000173,300
Oil Age miles5,00011,20015,82021,07926,0152,5001,5007,00012,00018,70028,00033,300
Makeup oil quarts0.75
Filter Age miles5,00011,20015,82021,0794,9362,5001,5002,0005,0006,7005,0005,000
Oil Changednonononoyesyesyesnonononoyes
Filter Changednononoyesyesyesyesyesyesyesyesyes
BrandHPLHPLHPLHPLHPLHPLHPLHPLHPLHPLHPLHPL
Viscosity5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO5w-20 HDEO
new formulanew formula
Wear Metals
Iron513214262196915172333
Chromium<1<1<122<1<1<1<1<112
Nickel000<100<100<1<1<1
Titanium<1<1<1<12<1<1<10<1<1<1
Silver<1<1<1<1<1<10<10000
Aluminum3315542415812
Lead00<11<1110003<1
Copper31016396664316572696465
Tin0<10<1<1<1<1000<1<1
Antimony00<1<1--------
Vanandium<1<10<1<1<10<10<1<1<1
Cadmium000<1not reported0000000
Additives
Boron18181424323202200116
Barium301020000410
Molybdenum523521500518545535492548600590494573
Manganese<1<1<1231<1<1<1<1<12
Magnesium46244643046746110781091981115810599981131
Calcium342232373203337935622812243124582767264523402637
Phosphorus788777760754802113710941024109510418551089
Zinc9489248849499881326117612711411127111291404
Contaminants
Silicon111115253317121318172022
Sodium44588403541619
Potassium1<12341022343
Fuel %<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0<1.0
GlycolNEGNEGNEGNEGNEGNEGNEGNEGNEGNEGNEGNEG
Soot%0.10.10.10.10.10.10.10.10.10.100.1
Fluid Condition
TBN12.37.35.053.9852.851216.810.89.288.1167.76
Viscosity8.89.19.49.5610.69.29.41010.411.612.613.2
Oxidation 515.322.524.13145.30 (39.7)12(51.7)14.3(54.0)21(60.7) 24.4(64.1)27.1(66.8)
Fantastic Data! The oxidation & viscosity end of life looks like the 28,000 mile mark. That mileage also marks before you had to add any make-up oil too. You've done an excellent job on testing this HPL oil across your "fleet" on everyday vehicles that we'd normally only see on OTR trucks.
I disagree with most here; I'm going to be the voice of dissent.
- The Fe wear rate over the entire OCI is admirably low; approximately 1ppm/1k miles. In fact, the wear rate over the last 5 UOAs is very steady; only varying a few tenths up or down.
- The Al wear is increasingly, but not alarmingly so. Oddly it dropped shortly after the OCI, but then has a fairly steady increase. Overall, I think there was still some headroom here.
- The other wear metals were inconsequential.
As for the vis and ox, I do see they have a fairly substantial increase. But they don't seem to be affecting wear at the point of OCI. The TBN was strong enough to run further. I think there was life left in that lube in terms of wear control. Whether it was affecting fuel economy due to the vis increase, that's hard to prove. The MAIN purpose of lube is to control wear, and the lube was still very much doing its job well. I believe condemnation was premature because the wear rates were not showing any correlation to the vis and ox. Without correlation, there can be no causation.
If this next load goes as well, perhaps push it a tad further.
I agree that wear is still very low, however another of my criteria is cleanliness. There is no varnish on the inside of the engine, but with oxidation being at 27 and enough oxidative thickening to bring the viscosity up 3 cSt, at some point we are going to get varnish. When? I don't know, but I know for sure I would not like to find out. Actually, I would like to find out, but not with my engine. If wear were my only criteria, I would let it run another 5k.
I believe Oil Analyzers condemns oil when it reaches +17 oxidation over virgin. Interesting that the two labs differ here.
Where did the Boron come from on the last analysis? 16 is not a lot, but it's significantly above the previous 0-2 readings.
Fair enough; the concern is understood.
I counter with this, regarding oxidation and varnish ... your fear isn't unwarranted. I just think it's not as big a deal as you may fear.
I say that with the utmost respect; you're certainly willing to push the envelope further than most folks ever would do, even in their wildest nightmares.
Let's say some light varnishing does start to happen. So what? Given how well we've seen HPL clean other heavily varnished engines, are we to presume that this potentially newly formed varnish which would occur is somehow immune to the cleaning ability of a new load of HPL? I think we've seen plenty of examples that HPL can clean a LOT of stuff up; far worse than what might happen in 5k "more" miles. I believe that whatever light varnish which might occur could easily be "re-cleaned" upon the next HPL load. HPL has already proved it can clean your engine (we've seen the pictures!).
Worst case scenario: OCI extension leads to a little bit of varnish (with the net benefit of confirmation where the OCI limit is).
Reaction plan: Upon the next OCI, use more HPL to clean the residual, and you dial back the OCI a bit.
If we were to do a FMEA, the RPN rating would look like this:
RPN = Occurrence x Severity x Detection
O = The possibility of occurrence that a 5k mile OCI extension in your situation would generate varnish is moderate; probably rated at a "4".
S = The severity of varnish created over that same 5k miles is really low impact; probably a "2"
D = The possibility of varnish being undetectable; rated at a "3"
Your RPN value is a whopping 24 points for that previous run.
Most companies don't require mitigation plans until RPNs get over 100, and would be grateful to have RPNs so low as yours.
The "risk" of varnish causing irreparable, irreversible harm to your 3.6L engine is minute; really, really very small.
There is no real reason to use the UOA to guesstimate the oxidation effect when you can just look under the valve cover to see.
Wear rates not detrimentally affected? Run the OCI out.
Varnish not present? Run the OCI out.
Run the OCI until a change in output(s) actually happens, then look for the correlation of input(s) that likely caused that change.
And yes, I am willing to put my money where my mouth is. As soon as "break in" is complete on my ES350, I'm changing to HPL and running the OCIs way out.
I will practice what I preach.
If we were to do a FMEA, the RPN would look like this:
I will get the camera out tomorrow and take some under valve cover pictures. If all is perfectly clean, then I will think about it.
With only a 6.5 quart sump, most OTR trucks hold at least 40-60 quarts.
That is quite a feat for that 6.5 quarts. Nice work!
On top of that it may be that the oil was getting to a point of more easily burned off. Did you note when the oil started burning off like towards the end or consistently throughout? I would just think that the more oil is toasted it's going to be easier to burn off. I know other aspects can affect this like towing etc.
The oil consumption was from a worn out PCV valve. After the valve was replace, the oil consumption returned to zero.
Your 20wt virgin oil is now at 13cst. After you're done looking under the valve cover whether anything is starting to accumulate check the pistons too.
I've seen engines run on euro oils that have pretty clean valvetrain and timing system, but had rings severely clogged. Those were DI engines; if this is port injected maybe you'll get away with it. Either way, I see no advantage in buying a $$$ oil and then running it this hard. As far as I'm concerned if an oil has thickened out of grade it is done. It's not my money or engine though, so best of luck.
If you're planning to continue these extended runs it would be interesting to see the TAN to have the complete picture (after all controlling acids is the mission). TBN isn't really of much value in these long oci's.
