This sample was pulled from my 2014 Dodge Durango with a total of 158,700 miles and 18,700 miles on the oil. The oil is HPL's 5w-20 CK-4 based formula and has been run since Feb 9, 2022, about 16.5 months. The lab is Wearcheck. I believe we are finally at the point that the cleaning is subsiding after running HPL's high ester and AN oil for the last 48,000 miles. The usage on this 6,700 mile run was >95% high speed driving down the interstate. There was 1/4 quart (1 cup) of makeup oil. This is the equivalent of three oil samples, so the oil consumption remains at zero. Most of the fuel used for this 6,700 mile run was E-85.
The previous UOA thread is here:
This is the filter thread I posted with the filter that was changed when this oil sample was taken:
I have normalized the oxidation by taking the absolute value and subtracting the base oxidation value of virgin oil. Esters are high in carbonyl groups, ASTM D7414 will show high oxidation even in virgin oil. The corrected oxidation is 21, which is still below Wearcheck's suggested condemnation limit of 25.
The TBN, wear, and contaminants all look good. Oxidative thickening is taking place as the viscosity has increase by about 19%. The viscosity rose from 9.4 to 11.6. You can see that the VIIs in this oil don't shear, so oxidative thickening is not masked at all by VII shear. The viscosity increase is not causing wear, which is evident by all the metal numbers, which frankly are incredibly low. Given that the TBN is still 8.11 and the Fe only increase by 2 ppm, which is an outstanding 0.3 ppm/1k miles! This oil is still serviceable and will be run for another 5,000 miles.
A thought: Is the viscosity increase cause by oxidation useful viscosity? Said another way, will the higher viscosity cause by oxidative thickening increase the oil's hydrodynamic lubrication?
[TD]
[TD]
[TD]
[TD]
[TD]
Dodge Durango 3.6L - HPL CK-4 5w-20 - 12,000 miles on oil - 152,000 total
This sample was pulled from my 2014 Dodge Durango with a total of 152,000 miles and 12,000 miles on the oil. The oil is HPL's 5w-20 CK-4 based formula and has been run since Feb 9, 2022, about 14.5 months. The lab is Wearcheck. There is still cleaning taking place. This is the filter thread I...
bobistheoilguy.com
Dodge Durango 3.6L - second run of HPL 5w-20 - 18,700 miles on oil - filter pictures at 6,700 mile change interval run from 152,000-158,700 miles
The first filter from this second run of HPL HDEO 5w-20 is here: https://bobistheoilguy.com/forums/threads/dodge-durango-3-6l-second-run-of-hpl-5w-20-5-000-miles-on-oil-filter-pictures-at-5-000-mile-change-interval.359054/ The second filter from this second run of HPL HDEO 5w-20 is here...
bobistheoilguy.com
Sample Information | start first run | end first run | flush old formula | start second run | ||||||
Sample Date | Feb 2020 | Dec 2020 | March 2021 | August 2021 | October 2021 | February 2022 | March 1, 2022 | September 5, 2022 | April 19, 2023 | June 13, 2023 |
Machine Age miles | 116,000 | 122,200 | 127,420 | 132,679 | 137,615 | 140,000 | 141,500 | 147,000 | 152,000 | 158,700 |
Oil Age miles | 5,000 | 11,200 | 15,820 | 21,079 | 26,015 | 2,500 | 1,500 | 7,000 | 12,000 | 18,700 |
Filter Age miles | 5,000 | 11,200 | 15,820 | 21,079 | 4,936 | 2,500 | 1,500 | 2,000 | 5,000 | 6,700 |
Oil Changed | no | no | no | no | yes | yes | yes | no | no | no |
Filter Changed | no | no | no | yes | yes | yes | yes | yes | yes | yes |
Brand | HPL | HPL | HPL | HPL | HPL | HPL | HPL | HPL | HPL | HPL |
Viscosity | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO | 5w-20 HDEO |
new formula | new formula | |||||||||
Wear Metals | ||||||||||
Iron | 5 | 13 | 21 | 42 | 62 | 19 | 6 | 9 | 15 | 17 |
Chromium | TD] [TD]TD] [TD]TD] [TD]2 | 2 | TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] | |||||||
Nickel | 0 | 0 | 0 | TD] [TD]0 | 0 | TD] [TD]0 | 0 | TD] | ||
Titanium | TD] [TD]TD] [TD]TD] [TD]TD] [TD]2 | TD] [TD]TD] [TD]TD] [TD]0 | TD] | |||||||
Silver | TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]0 | TD] [TD]0 | 0 | |||||||
Aluminum | 3 | 3 | 1 | 5 | 5 | 4 | 2 | 4 | 1 | 5 |
Lead | 0 | 0 | TD] [TD]1 | TD] [TD]1 | 1 | 0 | 0 | 0 | ||
Copper | 3 | 10 | 16 | 39 | 66 | 64 | 31 | 65 | 72 | 69 |
Tin | 0 | TD] [TD]0 | TD] [TD]TD] [TD]TD] [TD]TD] [TD]0 | 0 | 0 | |||||
Antimony | 0 | 0 | TD] [TD]TD] [TD]- | - | - | - | - | - | ||
Vanandium | TD] [TD]TD] [TD]0 | TD] [TD]TD] [TD]TD] [TD]0 | TD] [TD]0 | 0 | ||||||
Cadmium | 0 | 0 | 0 | TD] [TD]not reported | 0 | 0 | 0 | 0 | 0 | |
Additives | ||||||||||
Boron | 181 | 81 | 42 | 43 | 23 | 20 | 2 | 2 | 0 | 0 |
Barium | 3 | 0 | 1 | 0 | 2 | 0 | 0 | 0 | 0 | 0 |
Molybdenum | 523 | 521 | 500 | 518 | 545 | 535 | 492 | 548 | 600 | 590 |
Manganese | TD] [TD]TD] [TD]TD] [TD]2 | 3 | 1 | TD] [TD]TD] [TD]TD] [TD]TD] | ||||||
Magnesium | 462 | 446 | 430 | 467 | 461 | 1078 | 1091 | 981 | 1158 | 1059 |
Calcium | 3422 | 3237 | 3203 | 3379 | 3562 | 2812 | 2431 | 2458 | 2767 | 2645 |
Phosphorus | 788 | 777 | 760 | 754 | 802 | 1137 | 1094 | 1024 | 1095 | 1041 |
Zinc | 948 | 924 | 884 | 949 | 988 | 1326 | 1176 | 1271 | 1411 | 1347 |
Contaminants | ||||||||||
Silicon | 11 | 11 | 15 | 25 | 33 | 17 | 12 | 13 | 18 | 17 |
Sodium | 4 | 4 | 5 | 8 | 8 | 4 | 0 | 3 | 5 | 4 |
Potassium | 1 | TD] [TD]2 | 3 | 4 | 1 | 0 | 2 | 2 | 3 | |
Fuel % | TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] [TD]TD] | |||||||||
Glycol | NEG | NEG | NEG | NEG | NEG | NEG | NEG | NEG | NEG | NEG |
Soot% | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Fluid Condition | ||||||||||
TBN | 12.3 | 7.3 | 5.05 | 3.985 | 2.85 | 12 | 16.8 | 10.8 | 9.28 | 8.11 |
Viscosity | 8.8 | 9.1 | 9.4 | 9.56 | 10.6 | 9.2 | 9.4 | 10 | 10.4 | 11.6 |
Oxidation | 5 | 15.3 | 22.5 | 24.1 | 31 | 45.3 | 0 (39.7) | 12(51.7) | 14.3(54.0) | 21(60.7) |
[TD]
[TD]
[TD]
[TD]
