The first filter from this second run of HPL HDEO 5w-20 is here:
The second filter from this second run of HPL HDEO 5w-20 is here:
The pictures below are from the third filter from the second run of HPL HDEO 5w-20. The oil now has accumulated 18,700 miles of use. HPL HDEO 5w-20 has been in use for a total of 47,100 miles, again this is the second run. The UOA has been sent in and the results will be posted when I get them back.
This is the first time I have observed no carbon or debris in the filter since installing HPL oil 47,000 miles ago. The last filter (second post above) had a considerable amount of carbonaceous material. Why did the first filter have some, but not much trapped material, the second had a lot, and the third nothing visible? I don't know and can't explain it. However, there was one difference in driving style during the second filter run. The Durango sat for three months without being started. How can that explain the large amount of trapped carbonaceous material? I was hoping you could explain it
The amount is sparkly metal flakes in the filter was usual. The camera doesn't capture them, but to the naked eye, they are highly visible in the bright sunlight.
At this point I believe it will be safe to change the filter at 10,000 mile intervals and will pull the filter at 5,000 intervals and carefully take a peak to see if there is any trapped material. This is a cartridge filter that retains no oil while sitting, so removing it and looking between the pleats is simple.
Dodge Durango 3.6L - second run of HPL 5w-20 - 5,000 miles on oil - filter pictures at 5,000 mile change interval
Below are pictures of the oil and filter run for 5,000 miles. This is my second run of HPL 5w-20 HDEO in my 3.6L Durango. The total miles on HPL oil is now 33,500 miles. Because the filter was so loaded with deposits being cleaned during my first run of HPL, I decided to change the filter every...
bobistheoilguy.com
Dodge Durango 3.6L - second run of HPL 5w-20 - 12,000 miles on oil - filter pictures at 5,000 mile change interval run from 147,000 - 152,000 miles
The first filter from this second run of HPL HDEO 5w-20 is here: https://bobistheoilguy.com/forums/threads/dodge-durango-3-6l-second-run-of-hpl-5w-20-5-000-miles-on-oil-filter-pictures-at-5-000-mile-change-interval.359054/ I have stated that I will change the filter every 5,000 miles until the...
bobistheoilguy.com
