Dodge Durango 3.6L - second run of HPL 5w-20 - 18,700 miles on oil - filter pictures at 6,700 mile change interval run from 152,000-158,700 miles
wwillson
Staff member
Colorado
The first filter from this second run of HPL HDEO 5w-20 is here:
The second filter from this second run of HPL HDEO 5w-20 is here:
The pictures below are from the third filter from the second run of HPL HDEO 5w-20. The oil now has accumulated 18,700 miles of use. HPL HDEO 5w-20 has been in use for a total of 47,100 miles, again this is the second run. The UOA has been sent in and the results will be posted when I get them back.
This is the first time I have observed no carbon or debris in the filter since installing HPL oil 47,000 miles ago. The last filter (second post above) had a considerable amount of carbonaceous material. Why did the first filter have some, but not much trapped material, the second had a lot, and the third nothing visible? I don't know and can't explain it. However, there was one difference in driving style during the second filter run. The Durango sat for three months without being started. How can that explain the large amount of trapped carbonaceous material? I was hoping you could explain it :)
The amount is sparkly metal flakes in the filter was usual. The camera doesn't capture them, but to the naked eye, they are highly visible in the bright sunlight.
At this point I believe it will be safe to change the filter at 10,000 mile intervals and will pull the filter at 5,000 intervals and carefully take a peak to see if there is any trapped material. This is a cartridge filter that retains no oil while sitting, so removing it and looking between the pleats is simple.
Until the UOA says I should change it. Factors will be TBN, oxidation, viscosity, contaminants, and/or wear metals.
wwilson, is this a vehicle you bought brand new?
Could you clarify what oil you used before HPL and what your OCI's were?
Yes
From new to 112,000 miles, I ran 0w-30 syn PCMO in the winter and 10w-30 syn blend HDMO in the summer. No oil changes more than 8,000 miles. Take some time to let that settle in.
Move along folks....nothing to see here
How far do you intent to go on the same oil w/ just filter changes???
I read somewhere online a while back (which proves its truth, LOL) that the filter change and top off method had merit, it that the ad pack was "refreshed" by the new oil. I am not sure about it though. I suppose one variable would be how the filter was oriented, so that when changed you had to add a quart or so.
And what do you intend to prove? Honest question. Just becuase the engine ran X miles between those changes does not mean that it will be the same on later changes. Is it just a test of the oil?
Yes, if you add top-off oil, you will see an increase in TBN for example. I have only added 1/4 quart (one cup) of make-up oil to replace the three samples that I've pulled out. 1/4 quart is not much (3%) in a 6.5 quart sump, so we won't see much difference in this case. Remember, changing the filter in the Pentastar drains no oil.
And what do you intend to prove? Honest question. Just because the engine ran X miles between those changes does not mean that it will be the same on later changes. Is it just a test of the oil?
It's pretty simple. I see no sense in draining oil that is capable of more use. I am also a perpetual experimenter, so I experiment within rational bounds. We can see in the UOAs if the oil is spent and needs to be change, else it can continue in service.
My goal is to not waste oil, not change it so often (it's not as much fun as it used to be), and to learn with real data about how far this oil can allow me to safely extend change intervals. To me there is little risk in sensibly extending the OCIs.
I am also using the knowledge gained about HPL's extended drain capabilities to extend drain intervals on our farm machinery with very large sumps. I now trust HPL enough to extend OCIs on very expensive agricultural engines, which saves about $400 each year on each machine compared to rotely changing the oil every year or at 100 hours like we used to. Take $400x10/yr and pretty soon you're talking real money.
