My 2007 Accord with 666,800 miles (Valvetrain Shots)
Snapped a picture of one of my exhaust cam lobes with my borescope. 2006 Accord K24. 281,000mi. Have used 20 grade oils the entire life of the car except for my previous OCI, I used M1 Euro 5w-30.
I'm not really worried about the wear. Car runs great. Still get >32mpg on long highway drives. UOA's are stellar.
However, since we're on BITOG....
I wonder if this is something that increasing viscosity would help. Or, if an oil with a ton of moly, boron, and/or ZDDP would help. Maybe all of the above?
It looks like the surface hardening is already breached, so nothing is going to really save it at this point. An oil with more AW additives (higher levels of phosphorous, like an LL-01 lube) might have been more effective at preventing the wear, but I can't say for certain.
Looks good to me.
A little wear on the cam lobes? After 666K? A tribute to the engine design.
Looks really clean as well.
IIRC, you wanted a high miles K24 when you bought this car. You got one and it's still doing well for you. Good for you and Honda.
Incidentally, this Gen 7 is a really good generation of the Accord, maybe the best.
It might have helped if someone would have touched these things periodically.
I was told that the clearances on a OHC get tighter as the engine wears.
This is the Legend (SOHC) at ~438k. Only the exhaust side is adjustable. The valve train isn't quiet but the lobes aren't trashed either.
If the PO had it dealer serviced there is a good chance they had it done. I think it is in the service schedule.
Looks spotless in there!!
  • Like
Reactions: hrv
The car is rusting so run it until it dies or really embarrassing to drive or fails state inspection.
The seat has to be pretty worn and likely many little things are broken or don't work.
I spoked to my regular service advisor who also serviced the car since it was new, and he mentioned that the previous owner had the valves adjusted on it regularly. It's not really in the service schedule. For these engines, Honda just says to adjust them if/when noisy.
Surprisingly, everything still works except the seat heaters. The leather is actually in quite good shape, and only recently started to tear on the left side bolster. No state inspections here. It's just my winter beater, but I hope to keep it going for as long as possible regardless. It's more comfortable on long trips than my Civic, so we do take it on vacations as well.
Look into the cam job. Super easy on my ohc Mercedes diesels.
I’ll bet you can get some lower mileage clean cams for cheap, not dealer prices. The wild card is what else should be replaced in the lifter system, since something there is rough and causing some bad wear.
I thought about it, but I'd rather just replace the engine if I were going to do more to it. It has stuck rings and burns a lot of oil, and would essentially need an entire rebuild. I'll keep it going for now since it still runs fine.
In the past on my Honda I would adjust them around 100000 miles noisy or not...
The cams had an issue of delaminating in those years, I saw one with only 60k that looked almost as bad as that. If it got to almost 700k like that i'm sure it will keep on going a long while lol
