- Joined
- Mar 19, 2022
- Messages
- 879
This is my 20 Promaster 2500 with 85k. I bought it used in 21 with 30k (Amazon lease).
This is my work vehicle, I've run Pennzoil Platinum 5w30, and Mobil 1 Euro 0w40. All oils changed between 5k and 6k.
Oil filter housing oil leak so I tore into it. There is a lot of stuff in the way where they shoe-horned this pentastar where a Fiat 4cylTD was supposed to go.
Had to replace leaking radiator which made access much better for this application.
Found weeping valve cover Gaskets so decided to change those while I was there. Low and behold I see this. Some other cam lobes and rollers look similar. Not inspiring confidence at all.....
What would you do?
Can just feel the right side with your fingernail. The roller has a similar finish on ¾ of it. Other lobes are starting to look like this as well.
I'm tempted to change all the rollers, but the rear bank will be a total PITA. Rear bank looks better overall for some reason.
What would you do?
