Wiped a cam lobe?
Originally Posted By: Donald
I think the Yugo factory was bombed by the US many years ago in a Serbia confict?
By NATO, officially.
From Wikipedia:
"In 1999, during the Kosovo War, NATO bombed the Zastava Automobiles plant in Kragujevac, Serbia because it was considered a threat since Zastava Arms infrastructure was also located on site. Zastava Arms makes rifles and pistols. Nevertheless, the bombing did not completely halt the production, as there were still three working shifts even during the height of NATO bombing (Zastava factory has operated continuously since it was built). Some of the car manufacturing buildings were damaged and numerous workers were injured."
An old article from the Baltimore Sun, contemporaneous to the bombing:
http://articles.baltimoresun.com/1999-05-18/news/9905180111_1_yugoslavia-zastava-nato
Originally Posted By: default
No magnet that I recall. Lever them up with a screwdriver a bit and then pop it out with piece of wire. Slide out with a another tool I made out of wire, mic it, record, put it back, repeat 8x, check all the clearances, do math, figure what i need and what can be swapped around, email my shim guy and swap everything around, check work and done.
Reason I asked was if any of the shims got magnetized either by using a magnet to remove them or by use of a magnetized tool, it can easily attract fine iron particles that, once the engine is operated, can wipe out a love pretty quick. Some aftermarket shims can do this too if the shim material is harder than the lobe. I've seen a few motorcycle cams wiped out because of the above.
