This car is a REAL streetcar. It is a 94 LT1 small block. Makes about 575hp on pumpgas(Shell 93).
I did a good bit of reading on the subject of making a solid roller cam live on the street. What I gathered from the reading was this. Use a pressurized roller lifter(I did, a Comp Cams Endurex) Keep the idle oil pressure above 30 psi hot(I have) Put the CORRECT springs on the car and run a GOOD oil.
Currently the setup has 2500 miles on it, I tore it down at 1000 miles because of a ring problem, no visible wear on anything other than a few side scuff marks on the lifters.
I have changed the oil about every 500/700 miles just to keep an eye on whats going on inside the engine.
Here is my question, will this car pick up power going to the Rotella T synthetic? Will it hurt the solid roller cam? How much power is to be had going from the 15-40 Rotella to the 5-40 Rotella Synthetic?
Thanks in advance.
David
Thanks in advance.
David
