Thank you. I regret selling it. The guy who bought it won’t sell it back.
David
David
verrrry pretttty...Until a few years ago, Richard was the only person who has been a speaker at every PRI trade show. At these events I used to chuckle because other meeting rooms were not that crowded while his room had a mushroom cap shaped crowd in the hallway looking into the room that was 100% full.
This is Richard working on one of my V8 bike engines.
This is the engine before the chrome pan and carbon fiber valve covers went on.
Weight is an issue on a motorcycle. Replacing the cast valve covers with carbon fiber saved 7 pounds and removing the stand gets this thing just under 300 pounds. This is an all aluminum 421 making 600 Horsepower
And the end result is fantastic.
Bottom line on the power subject is yes. If you are going high performance too much power is almost enough.Wow David! Too much power is almost enough..
Diesel oil is what you put in the fuel tank. HDEO is the oil you put in the crankcase. I used Chevron DELO 15w40 [ 20W50 gave a bit more moil pressure though] in my last 7,500 engine in my last boat engine it worked and at tear down all looked good. The valve train always looked bad no matter what oil was used , consider the valve train to be disposable.. The zinc additive isn't needed.I think I'd run some 15w40 Chevron diesel oil with a bottle of zinc additive.
That's not a recommendation though. Don't want to be responsible for ruining somebody's engine.
Wow David! Too much power is almost enough.. All kidding aside, that is a really neat motorcycle!
Mobil 1 FS 0w40 is the answer. Have a nice day.
I originally put this engine together around 8-10 years ago.....and I did contact Mobil for a recomendation....and I did get the 15w50 mobil 1. I just dont like that heavy syrup....and I dont run long high rpm events. I always worry about the oil pump driveshaft and the strain on the distributor
