I know this has been covered before but this is what has always concerned me about these products. People who recycle oil mix other things into the oil like: solvents, paint, paint thinner, brake fluid ATF, anti-freeze, Chlordane [yes I read that somewhere], etc, etc. etc. to get rid of it. It might be the greatest thing since sliced bread, but not at the cost they offer it for. I'll stick with the tried and true, dino for the beater, synthetic in the E-150 and Jeep. JMO
Who knows maybe when I learn more about it and see some actual testimony from people I trust, not marketing hype, and results I can verify, I might give it a shot.
I guess we're lucky that "regular" oil flows clean out of the ground.....luckily nothing's mixed with it down there.
More people should really take chemistry....
Originally Posted By: jsjonz01
What kind of base stock do you end up with? There is no guarantee that the used oil is still Valvoline, right? Couldn't it be a mixture of several different brands after the recycling process has been completed? Just some questions... I support this idea, and I also am a Valvoline user.
Yes, when God put crude in the ground, he made sure the Valvoline Oil people knew which oil was theirs.....I mean, what if they accidentally pulled out Mobil crude? How embarassing....
Originally Posted By: A_Harman
I don't mind reading a newspaper made of recycled paper.
When it comes to a product which is protecting my $4000 engine, I'm a little more difficult to convince. If it were available at a price significantly less than regular dino oil, I would buy it and put it in my lawnmower. But I would want to see a fully informative spec sheet on it before I would use it in a car. I'm uncomfortable with the idea of the random mix of motor oil, tranny fluid, hydraulic fluid, machine oil, cutting fluids, and gear oil, whether conventional or synthetic, that makes up 50% of NextGen's base stock. How do they assure quality from batch to batch?
How does Valvoline currently control quality from batch to batch on "regular" oils? Well, that's how they do it here...... BTW, all those oils you mention also come from crude. HMMMMM....wonder if there's a method to seperate it.......(hint: distillation)..
Really.....my faith in BTOG is fading fast.....
