Might be wise to remember that not everyone can afford to drop between $70 to $94 dollars for 6 qts of HPL products.
.Thats all fine and dandy. I'm glad you have had good luck with HPL. Im sorry you have had so many doctors in your life to praise and stay away from. I'm not sure how to relate doctors to engine oil.
Valvoline Restore and Protect is new as of 1-2 months ago. Ive seen this song and dance time and time again on BITOG. The new thing comes out, its a bangwagon. Everybody jumps on. Dave is a good guy. I have met Dave. Dave is in the market to sell oil. I'm glad he is successful.
You seem easily swayed to now jump onto the Valvoline Restore and Protect bandwagon. Im sure its going to solve all of your oil related problems and clean all your dirty engines better than any other oil there is. Have you been finding lots of "junk" in your filters? Maybe its time to shorten your oil change intervals or not jump on the bandwagons?
the OP was asking which one…. HPL is in the thread name.Might be wise to remember that not everyone can afford to drop between $70 to $94 dollars for 6 qts of HPL products.
Absolutely. But it is nice that we have that option, to buy these products at a discount, thanks to Dave's participation on the board.Might be wise to remember that not everyone can afford to drop between $70 to $94 dollars for 6 qts of HPL products.
Nobody said it was for everyone.Might be wise to remember that not everyone can afford to drop between $70 to $94 dollars for 6 qts of HPL products.
Again - wrong conclusion. Arrived at by a mis-representation of other posts.Thats all fine and dandy. I'm glad you have had good luck with HPL. Im sorry you have had so many doctors in your life to praise and stay away from. I'm not sure how to relate doctors to engine oil.
This has boggled my mind since discovering this forum a few years ago! It is cheaper in the long run. I have paid $11.23/quart shipped for two pails of vanilla PCMO HPL and I thoroughly expect to get at least $20k miles per fill. Great ROI imo.Nobody said it was for everyone.
But, and this is a really important point - if used to the oil’s full potential, it can easily be cheaper/mile than regular oils. Even at $90/six pack.
That is why the fleet sales are so big - big operations, in excess of 10,000 vehicles, have found that by correctly stretching the drain interval, they reduce down time and the cost/mile goes down.
Really important consideration for some operators - where a fluid change takes a very capital-intensive machine out of operation for weeks - being able to use the hydraulic fluid for four times the interval (based on testing and monitoring) saves them literally millions.
How many changes did Wayne avoid on his Durango with this run?
https://bobistheoilguy.com/forums/t...-total-34-000-miles-on-hpl-hdeo-5w-20.377792/
I know the HPL was cheaper per mile. He got 6 times the life of the “cheap insurance, change every 5,000 miles” crowd. He would have to be using oil that cost under $2/quart, and FREE filters, to equal the cost of his HPL run.
It is fascinating that people say, “oil is cheap insurance” and in practically the same breath, say, “that HPL oil is too expensive” when the actual cost/mile is lower because of the long life.
So, if you’re in the “cheap insurance” crowd - ironically, you are spending more on your cheap oil than going with HPL.
But yet they’ll drop $26-35 three times a year on 5k OCIs at WM. Plus 3 filters…Might be wise to remember that not everyone can afford to drop between $70 to $94 dollars for 6 qts of HPL products.
Others will drop $26-$35 twice a year on 7.5K OCIs at Walmart too, and save an OC. With 2 filters. Some people here do determine an OCI with UOA data and use that to determine their OCI. With DI engines my biggest fear would be fuel dilution which can wreck the best of oils, the only way to get that out is by changing the oil sooner rather than later.But yet they’ll drop $26-35 three times a year on 5k OCIs at WM. Plus 3 filters…
Not arguing that fuel is definitely not a lubricant… but, has anyone here actually had >5% dilution and had terrible wear metal results that then cleared up when the fuel dropped (on a ppm/1k rate, not just the total number). I haven’t seen (m)any…With DI engines my biggest fear would be fuel dilution which can wreck the best of oils, the only way to get that out is by changing the oil sooner rather than later.
Yes it's extra expense but if you are at 10K/1 year, how much of that was short run on the ICE? Maybe get a sample if possible and have it checked with UOA. If it comes back with no fuel dilution, good viscosity, good additive left then continue on until next year. If those results are different then maybe you want to consider an earlier change with whichever flavor floats your boat.Thank you all for your input. So my takeaways are as follows.
Mobil 1 Extended Performance: tried and true, why bother changing what works well?
HPL Premium PCMO: Many fans here. Great stuff for a number of applications, but not mine.
Valvoline Restore and Protect: The BITOG jury is still out on this one with only anecdotal evidence and one UOA.
Presently I am just over 50% of the recommended 2 year / 20k OCI on my vehicle so I have some time to wait for more evidence on the latter. My current thought is to just run the Mobil 1 Extended Performance through the winter where it will experience frequent short tripping to provide heat, then change it in the spring before a major road trip.
You made valid points. You also bumped a grade. There are a lot of people here who still won't deviate from the mfg 0W20 recommendation, so that extra margin of protection that many of us get by bumping up the grade doesn't exist for them and if MOFT isn't maintained bad things can happen. I'm not disputing nor am I challenging the quality or the value of HPL oil. I'm a customer too, and still have a couple of bottles of their engine cleaner. My point is the only way to get fuel dilution out of an engine is to change the oil that's all, and changing the oil at 7.5K vs 5K as in your example changes the math quite a bit.Not arguing that fuel is definitely not a lubricant… but, has anyone here actually had >5% dilution and had terrible wear metal results that then cleared up when the fuel dropped (on a ppm/1k rate, not just the total number). I haven’t seen (m)any…
I’m asking but also partly feel this is almost another “LSPI boogeyman”… my Ascent had 6.5% fuel (and 47ppm silicon!) and was actually below 1ppm iron per 1k miles. Looking at the Ascent forums (where their witchcraft beliefs and utter lack of understanding about all things mechanical makes my head hurt after reading just a handful of posts) most of the folks there, even with as short as 1300km samples all the way up to 11k mi samples were in the 2.5-3+ ppm Fe/1k. None of them had fuel as high as mine, yet their iron was ~3x higher. Majority of them were using 0w20 because of a moderator there who every third post or so was screaming “If you use anything other than 0w20 Subaru will deny your warranty!!”… so happy that we’ve got mods here who don’t let that nonsense go on!
I’m not going to argue that >5% dilution shouldn’t be changed, because it should (when it’s identified, of course). However, fuel doesn’t accumulate linearly, and so if you’re only going by this you will always be short-changing the oil, for what appears to be little benefit.
On the Ascents specifically, I’m wondering if it’s really just a simple case that the mfr went too thin to protect the engine even without any dilution or shear- there was a 6.2k sample (1,100 miles less than mine) that had double the iron and half the fuel at 3.5%. That oil ended up at 6.9cSt while mine was still at 8.7cSt. If the SuperCar 0w30 that’s in the sump now ends up with similar or better results at similar mileage, the case will be closed in my mind.
Back to @kschachn’s physics- engines can have some crutches done on the engineering side like wider bearings and higher oil volume, but if MOFT is not maintained for whatever reason things get ugly quick. And if the engine was on the ragged edge with a “clean” 0w20, either abuse or fuel will cause rapid wear. So, I get your concern but haven’t really seen objective data to make it the only thing I’m worried about.![]()
Here is the one baseline UOA available for this vehicle. There's not much going on here. The user's manual recommends a 20K / 2 year OCI making the idea of an extended OCI somewhat difficult to grasp. How many of us would be willing to wait 3-4 years in order to test an extended drain interval?Yes it's extra expense but if you are at 10K/1 year, how much of that was short run on the ICE? Maybe get a sample if possible and have it checked with UOA. If it comes back with no fuel dilution, good viscosity, good additive left then continue on until next year. If those results are different then maybe you want to consider an earlier change with whichever flavor floats your boat.
For me based on my used oil analysis, I opt for earlier changes in my really short trip, not up to temperature engines. The highway drivers get 5k to MM (possibly 8000 miles). Oil flavors accordingly but reflect mostly commercial available and sale things.
If life ever changes and much longer drives than oil flavor and OCI may change if supported by UOA. I'm not a large expensive fleet and worried about that. The costs of used oil analysis is more than my cost of change, I did them for my reference. Like getting a yearly physical to see if any changes. UOA every couple years/mileage that keeps you happy.
IF you ever decide to try HPL or Valvoline Restore and Protect please be proactive now and C&P some filter pictures prior at those intervals and then after with the new oils. Hard to compare tried and true vs. new with your own eyes if not done along the way. Maybe no differences at all, maybe something, maybe an inexpensive (or better quality) borescope with some through fill cap or drain plug the same way. I was gifted a handheld camera one and a Cell phone plug in one. Never really saw need to purchase but since then used for seeing pipe leak, Bee hive in walls and multiple other things. Maybe I'll do some motor stuff if I remember next time.
I love doing oil changes but on the extreme ends of things, assuming my vehicle's engine was no limiting factor, between 3-4k mile OCIs and a 20k+ OCI, I'd prefer the latter. Though I would likely settle somewhere in the middle, doing 10-15k mile OCIs.If your engine uses no oil, has no fuel dilution issues, and want you want to minimize OCIs while keeping your engine clean in the process then HPL is your oil.
If you use oil, have fuel dilution, and dont like long OCIs and still want to clean a neglected engine, Valvoline Restore and Protect seems to be the oil based on initial data (time will tell) and price point.
If you want to maintain a clean engine at reasonable OCIs then Mobil 1 has been proven to do the job.
There is no one size fits all. Nice to have options.
I've run Ingersoll Rand, Atlas Copco, and Kaeser. K 4 THE WIN!industrial compressors are all the rage in my plant right now. cant keep one running for a week before it has some sort of failure. iirc its a dooson unit. we have portable CAT branded compressors running one of our trains right now.
unfortunately i don’t have any influence on as built stuff. i’m engineering project management over new construction/additions. i believe they have settled in on just keeping rental compressors hooked up.I've run Ingersoll Rand, Atlas Copco, and Kaeser. K 4 THE WIN!
Add to that, buying in say a 5 gallon jug or case of bottles brings it down even more.Absolutely. But it is nice that we have that option, to buy these products at a discount, thanks to Dave's participation on the board.
It is not just the oils you posted as my car had some varnish and Redline Performance Euro cleaned it all off on the first use/3,000 miles. I will not be using that oil again as I can get HPL cheaper and it appears to be a better oil to top it off. Redline has priced themselves out of my market.In the event the OP happens to have varnish, I thought this question might have value to ask. I know sludge is easy for a cleaner to clean, but that varnish is very difficult if not impossible to clean. Would HPL Engine Cleaner 30 or Valvoline Restore and Protect be a better choice to clean varnish? Or would both be ineffective against varnish?
