It can leak down, that's why you should do an oil change after the soak and why I did.Does the Berrymans leak past the piston rings into the crankcase of does it stay in the cylinder for the duration of the soak?
I never said completely sorted nor have I seen anyone say that. Perhaps there is an acceptable level of usage that OP is ok with that these oils can help him achieve. I’m well aware of Hyundai/kia engines having a drinking problem too, that can’t be fixed with oils, flushes, soaks, etc.I'd like to see an example of oil consumption on-par with the OPs sorted with just using XYZ oil.
You said "Seems to work for some on here." - I want to see any example(S) of any one here that has shown improvement just using one of the oils mentioned.I never said completely sorted nor have I seen anyone say that. Perhaps there is an acceptable level of usage that OP is ok with that these oils can help him achieve. I’m well aware of Hyundai/kia engines having a drinking problem too, that can’t be fixed with oils, flushes, soaks, etc.
PCMO=group III/OCP
PCMO premium=group III/star
PCMO premium plus=PAO/star
My...I would reach out to @High Performance Lubricants directly.
My understanding is that every single one of the oils that they have developed goes through all of the extensive testing of which their lab is capable.
Far more testing than you saw in that video.
They will have all of the detailed performance results from that testing of their regular passenger car motor oil, and I promise you, the viscosity breakdown susceptibility, the durability, as well as the cleaning and other benefits of their regular PCMO oil far exceeds the group 3/OCP that we saw in the video.
Solid point.These "cleaning" oils that everyone goes on about here ad nauseum are not intended to fix a serious oil consumption issue.
In the VRP mega-thread, post #1274.You said "Seems to work for some on here." - I want to see any example(S) of any one here that has shown improvement just using one of the oils mentioned.
Ok ill have a look.In the VRP mega-thread, post #1274.
I read on hear, quite a few people recommending Valvoline Restore & Protect engine oil. With it just coming out, do you have any significant evidence of the claims it makes?
I have read on other forums where it has quieted noisy engines, looking through the valve cover is cleaner, another one is where they used a bore scope on a Toyota engine..
Curious if any of you all seen any evidence..
Thanks..
- Scott S
- Forum: Passenger Car Motor Oil (PCMO) - Gasoline Vehicles
Well, short answer is, no.OP,
Did the 4 OCI's of R&P improve your consumption at all?
One use of HPL isn't fixing this.I say try the HPL once. This way you aren't out a lot of money. It is more expensive than VRP but as a one time experiment, it shouldn't break the bank (though, it isn't my place to talk about your finances as it's not my business). But of course, as said above, if you have to keep adding oil, use whatever you want at that point. Once my stash of other stuff is done AND I am out of warranty, I'll move to something like HPL or Amsoil SS.
Of course not! But I'm a sucker for trying things... And I don't "think" it could hurt anything.One use of HPL isn't fixing this.
Kendall Nitro 70If I had a car that was burning a quart of oil every week and VRP didn’t fix it I would just grab a bunch of Kirkland synthetic every time it goes on sale and just use that for topping up but I would not bother doing any more full oil changes. I would just change the oil filter every 10k.
(Although in reality I would probably get tired of topping up the oil so much and would get rid of the car. It’s not worth the headache)
in that case it was R&P plus HPL ECE. Hard to form a conclusion that you should buy valvoline from that.In the VRP mega-thread, post #1274.
Thanks..
- Scott S
SuperTech HMFS oil is the only oil I use @5,000 mile OCI.With your driving style and the mileage you put on, I'd be using SuperTech. The only way HPL or Amsoil pays for itself is with looong drain intervals (with analysis).
Please share with us your outcome with Valvoline Restore & Protect. Did it do cleaning and reduce your oil burning? If so, by how much?Didn't want to hijack anyone's thread about trying HPL or any of the ongoing discussions about HPL and Restore and Protect.
I'm almost half way through my 4th OCI with Valvoline's Restore and Protect. Im getting impatient waiting for a response from HPL so I thought I'd ask y'all since there's no shortage of members here that have used their products.
My question is, what's the best one I can get for my vehicle? To be clear, if I was wanting to try say, Amsoil for the first time, I personally would like to try the famous Signature Series (and I did) instead of their OE or next highest offering. I'm unfamiliar with HPLs products, so what their best of the best for passenger vehicles?
The car I drive is in my signature, and for those on mobile, a little trick to see signatures, hold your phone in landscape mode, and they should show up. It works for me when I do it.
A little more detail:
It's a 2019 Kia Sportage AWD (2.4L GDI) bought used with 98k in June. It's sits now with 120k, I've done four oil changes (5k OCIs) with the Valvoline Restore and Protect 5W30. Driving is a mix of "city" and highway, I commute 80 miles a day 5 days a week highway, and my wife puts about 40-60 miles suburban driving on it each night she works. In total the car averages 1000 miles a week more or less so I've been changing it almost every 5 weeks.
I plan to take the HPL to 7500 miles since anything more seems ill advised with these vehicles (Hyundai and Kias with Theta II) and anything less feels wasteful. However, due to my budget, and persistent oil consumption, I only plan on buying 2 gallons, that's a fill and three quarts of top off oil, which depending on the rate of consumption I experience, will last me until another change, or it won't and I'll have to buy something else (definitely topping off with VRP if it comes to it).
