- Joined
- Dec 20, 2024
- Messages
- 663
I have the same engine with currently 136k miles on it.
I have used Royal Purple full synthetic since the very beginning - yet the car started consuming 1qt/1000 miles around 70k miles, and the dipstick and bottom of my oil filler cap have always been chocolate colored.
I agree with everybody else here:
- Change your oil following the severe use interval. 3k to 5k miles. Any oil would be fine as long as it follows the requirements.
- Also follow the severe use interval for the transmission fluid. Don't go above 60k miles no matter how you use it.
Your best friend is the user manual. On the Hyundai, it's actually very, very correct. They don't BS you with extended OCI's and whatnot. They advise tightly spaced intervals for severe use, and severe use is anything involving city driving.
I believe most issues with these engines occur from not checking the oil level. An engine that goes through 1qt per 1000 miles and starts with 6qts will be down to 1qt at 5k miles. Space that 5k, and you end up with barely anything. I suspect the oil consumption will not be proportional, so maybe past 3k miles it will no longer be 1qt per 1000 miles and there will still be something left, but in the long term it is not good. So stay on top of your fluids and you should be fine.
Also note that these engines don't have hydraulic valve lifters, it's all shims, and those need to be checked at 100k miles or so. I haven't on mine, as the procedure scares me crapless.
Hi All,
Occasional lurker, first post here. Was planning on crashing @Avery4 's excellent thread about the two VRP tests, because I don't have that much info to share to justify yet another thread, but well, maybe it's not polite to crash other people's threads.
Anyway. I'm an oil snob. There's no other word for it. I'm like that British gentleman who got stuck on a desert island and built three identical huts. When he was eventually found he was asked "Why three huts ?", and he said "Well, the first hut is my house. The second hut is my club. And the third hut - that one...
- goblin
- Forum: Passenger Car Motor Oil (PCMO) - Gasoline Vehicles
