Valvoline R&P, Honda K24, 250k miles, report on progress
Very nice sequence of events cleaning that baffle in less than 8 thousand miles. That Castrol did its job for sure when opened up to do your valves. A couple guys I work with in there 60s swear on Castrol products keeping internals clean when opening the bottom and top ends. Keep on trucking....
My well maintained, barely broken in, K24W in my 2016 CRV EX just reached 43,000 miles and it's on its 5th OC of PUP. At 4,800 per year it's going to be a while before it gets into the high mileage club. It's nice to know that it has plenty of life left in it.
It idles smooth, but fully warmed up and in Sport mode, and it's looking for some open road or steep long hill to climb to show that it can deliver every one of the 185 horses it's rated for. It's like a sleeping sports car that somebody plopped a big box on top of it. Darn thing wants to get-up-and-go.
Really? Something must have changed in the K24 tuning on the CRV's. I've driven all generations except the newest ones and they're great vehicles - but glacially slow.
I wouldn't say the the K24 powered Elements or CRVs are glacially slow. Instead, I'd define their power as being "adequate". What I've noticed more than power is the brakes. With four people in our Element it takes noticeably more brake pedal pressure to slow the car (I use Honda OEM rotors and pads).
Scott
Which also makes them great for the new drivers. You learn to leave some room to get to speed, not cut off others. The higher seating position, space all good. My son had a high mileage, hand me down '04 as his first vehicle. AC seized up needed repair so it was down for a bit and he got a Forte instead. Fixed the '04 and my daughter had it for a bit also learning on it until tranny went at like 270k. Ran great but needed something else. Sister handed down the high mileage '08. Daughter loves it everyday.
Scott
It's probably just the transmission on the old ones. They just don't feel like they want to move. You have to really stick your foot in it to get it down shift once, I don't think I ever had my 2012 double downshift but I have a light foot.
Great report! I have a '14 TSX with a slightly revised K24 (K24A1 vs K24Z3) and am also running 4 (very short) OCIs of VRP 5W-30 on my low mileage car "just because". My bigger question is where in the world are you still getting German Castrol for the last 100K miles??? :)
This post - particularly the cleaning of the varnished baffle - inspired me to go check that same area on my K24 (2014 TSX w/ 30k miles I recently purchased at 25k miles). Yours actually maybe cleaner than mine with 220k less miles!!!!?
I’m on my 2nd OCI (about 600 miles in) of VRP 5W-30; 1st was very short with VRP and HPL EC30 for 2k miles and this one will be 2500, and 3 and 4 will be 5k miles each. This car was dealer maintained but presumably sat for very long periods of time or super super short tripped so the CARFAX showed 7 to 7500 mile OLM change intervals with that being 2-3 years on average.
I've been using Kirkland in the wife's cr-v since around 100k and she is at 169k now. Most all changes were 5k or less with the exception of one dealer change which was higher and I'm pretty sure I did longer OCIs with the 2 Amsoil SS changes I did and possibly a longer one with the one HPL OCI. I have I think 5 jugs of VRP with a few 0W-20 and a few 5W-20s. I am thinking about using at least 2 of the 5W-20 next. I don't have any noticable burning issues but I figure it can't hurt to clean things up a little. Maybe I'll go for a 3rd and 4th after but we'll see. Then, I would go back to Kirkland to finish up my stash there. I usually go by the MM which ends up being around 7k miles depending on how many city miles the car drives. Oil changes are usually 7 months when it is warmer and then 5 months when it is colder. I can only assume that is because she remote starts more and for longer in the colder months, a habit I have been trying to get her out of but have been unsuccessful.
Wow, color me impressed. For "marketing" (ah yes, I 'member all the exshperts screaming from the hilltops that it was all hype and marketing) it appears to do a pretty good job at doing what it says it will do.
Maybe the exshperts can chime in with a new theory to hate on it. I know, lets all claim that it weakens steel and iron and other metals......
Try a 2016 in Sport mode with the engine fully warmed up.
It might help that I keep the injectors clean by using Red-Line SI - 1 in the fuel, and PUP 0W - 20, and I have changed the CVT fluid 4 times with Honda fluid ( I know, overkill ) and rear end fluid twice, cleaned intake air sensors, new PCV, on it's 3rd oem engine air filter, antifreeze drain and fill with Honda premixed, Hunter alignment and tire pressures proper.
It is a liquid carnauba wax called "Insulator Wax"....they use it to wax power line insulators on power transmission towers.
The K24 cannot be praised enough. I have a K24 powered 2013 Accord with 236,000 on it and it runs like a clock. I run 5w-30 in Florida and it barely burns any. I fill it and dont have to add any between oil changes. I keep a close eye on it and give it the smell test for dilution as it's GDI. I drive it 23miles one way to work in a hot climate so I know I'm not at major risk. I have sent it off for a UOA and no significant dilution. Some sure but nothing to bat an eye at.
